fuel guage not working, 87 yota pickup
i have an 87 pickup and the fuel guage is below empty at all times and thats all it ever does it never moves, what might it be ? i was told something is disconnected but i cant find where and dont know what wire or wires run this or anything, all fuses are fine, etc,
what and where do i check on the truck ? 22R and auto trans if it matters ? thanks for anything
I also am user fastr68 here- Randy -'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee, |
I had this problem.
I had to change the float in the gas tank. You will have to drop the tank or take off the bed to get to the float. Hope this helps.
Re: fuel guage not working, 87 yota pickup
thats crappy
is this a common problem with the 80s pickups ? how do i find out how many sending unit to guage wires there are on these trucks ? just one or more than one ? positive or negative run through the sending unit out to guage ? empty send more or less ground or hot ? im thinking that first i would want to check the wire near the tank to make sure that its got no signal >? thanks
ok i found out that if you unplug it then the fuel guage should go to full, well i looked and all i can see out of the top of the tank is a pair of wires together and yellow round harness connector under there at pass side frame rail top by the tank, i unplugged that and the needle didnt move at all, with key on yes,
is either of those two wires the fuel guage sender wire at all then ?> or do two wires go to F.I. pump ? im removing the bed most likely tomorrow, this will help things along, i might even pull the sender out and check to make sure the kid that put in the new fuel pump before i had the truck did it right and to make sure the floater is still on the sender unit arm wiring diagram looks like shows brown wire for fuel guage from the tank sender unit right ? thanks for anythign
