Go Back   Automotive Forums Car Chat > Toyota > Celica
Old 07-31-2004, 01:44 PM
driftking777's Avatar
driftking777 driftking777 is offline
Send a message via AIM to driftking777 Send a message via MSN to driftking777
Arrow high flow cat
ok...anywho...i just went to an exhaust place to see how much some stainless steel exhaust would cost from the flex hose back...came to about 175 that with them welding on my Apexi N1 muffer...anywho...i want to get a high flow cat also...where can i get one...and what brand is it...has anyone tried it....i own the car in my sig...so try to be 5th gen specific...5sfe motor.
Current cars:
83 RX7: KA-T, t3/t4 turbo,Tial 38mm WG, MR coilovers, 5 lug conversion all around, TII brakes, hydraulic hand brake, 8" rear", 6 point cage, AMS Rebuild kit, Fully ported polished race head, Custom interior, JLine 6LR2 15x8, 16x9.5
Old 07-31-2004, 02:43 PM
Dober89 Dober89 is offline
Re: high flow cat
Catco makes them. You can usually pick them up on ebay for 40 or 50 bucks. Summit racing has them also. If you get a universal one, which you might have to because I doubt they have one thats celica specific, go out and measure the size of your pipes and also the length of the cat. If you are getting all new exhaust then the place should be able to accomodate for a shorter or longer one.
I think its a great mod to add with a high flow exhaust!! Theres a few other companies that make them but im drawing a blank right now. Check out summitracing.com or jegs im sure they sell more than one brand.
Old 08-01-2004, 12:22 AM
91 Celica St 91 Celica St is offline
AF - Advisor
Re: high flow cat
goto nopi.com they sell direct bolt ons for cat back systems, no welding requiered or anything, comes with hi flow cat pipes and muffler
Old 08-01-2004, 12:30 PM
Re: high flow cat
well just to make sure im not just stupid here but...is all your cats right from you exhaust manifold...because i went to an exhuast place that going to be doing my stainless 2.5" exhaust and he said that they cant replace that cat with a high flow becuase they dont make them...enlighten me.
Current cars:
Old 08-01-2004, 01:34 PM
Re: high flow cat
Im not sure what your trying to ask but the cats are usually located down from the exhaust manifold a bit. On my car they are under the passengers feet but thats because I have a y pipe and its a little longer.
There should be no reason though why they cant accomodate a high flow cat to fit. You just need to make sure you get the right sized one and if its a little longer they should just be able to shorten the exhaust pipes they are going to install.
Old 08-18-2004, 11:36 AM
AF - Advisor
Re: high flow cat
cat back means everything from the catalytic converter back... theres 5 pieces to ur exhaust...
exhaust manifold, then downpipe/aka flexpipe, then cat, then exhaust pipe, then muffler, catback is everything from the catalytic converter to muffler
Old 08-19-2004, 10:39 PM
Re: high flow cat
no seriously people...i'll take a picture of it tomorrow...my cat is right off my header...and the flange to off my header is like 6" around...huge...so i cant replace it with a aftermarket...thats what im trying to get at...apparently my cat is defrent then all yours.
Current cars:
Old 08-20-2004, 11:08 AM
AF - Advisor
Re: high flow cat
naw i have a humongus cat as well, post up pics as soon as u can
Old 09-08-2004, 11:34 PM
fiveSFE fiveSFE is offline
Send a message via AIM to fiveSFE
Re: high flow cat
na ur cat is the same. on the gt and gts the cats come right off the headers
Old 09-10-2004, 10:35 AM
AF - Advisor
Re: high flow cat
this is an a and b conversatoin, c ur way out, yeah all celicas come with a hugh cat, and then a small secondary.....if u want kick ass Hp gains get a stright pipe instead of ur cat
