Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 02-01-2002, 08:22 PM
drift's Avatar
drift drift is offline
Send a message via AIM to drift
Synapse/Missing Link MAP bypass valve
anyone have any experience using one? i installed one on my Prelude in lieu of bleeder valves, and now the ECU cuts fuel when it sees boost.
anyone else ever ran into this before? got a solution?
Old 02-02-2002, 10:53 AM
inferno inferno is offline
Send a message via AIM to inferno Send a message via Yahoo to inferno
Re: Synapse/Missing Link MAP bypass valve
Ummm, the missing link bypass valve is basically a bleeder valve. The only way your ecu should "see" boost is if you didn't install it properly or are running more boost than the valve is supposed to bleed off. Make sure that the vacuum lines are connected properly according to the instructions and get back to us.
The most powerful weapon known to man is the human brain. Unfortunately a lot of people are walking around unarmed.
Old 02-03-2002, 05:21 PM
pvang31019 pvang31019 is offline
had that happen with fishtank check valves, turns out 1 of the 3 were backwards....
Old 02-03-2002, 10:37 PM
drift's Avatar
found the problem... mine was missing a very essential part. the sealing O-ring was missing, so the valve would get pushed into the recessed chamber under boost.
thanks!
