Old 07-31-2004, 10:50 AM
oxygen800r's Avatar
oxygen800r oxygen800r is offline
timing belt replacement
my 98 gst has 56,3xx miles now and it's about time to change out the timing belt and a few other things. i have a warranty on the car that covers this, and i can choose where to take the car. would taking it to the dealer be the best bet? or an independent shop? i live in austin, so if any of you can recommend a good place...
on all my other cars i've ever had, i've done this type of work myself. of course they've never been turbocharged before...so it scares me a bit. i think i'll sit this one out and be happy just paying the $75 deductible and letting someone else do it.
what else should i be changing out right now?
tranny oil, radiator flush and fill...can anyone add to this list???
thanks.
-ryan
Old 07-31-2004, 10:52 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: timing belt replacement
The dealer is your best bet for the tbelt swap. They screw it up about 3/4 of the time, regular shops screw it up 95% of the time.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 07-31-2004, 10:54 AM
oxygen800r's Avatar
^^^ right right.
what else should i be doing at this point as far as maintenance?
Old 07-31-2004, 11:40 AM
TurbosR4me's Avatar
TurbosR4me TurbosR4me is offline
Maybe spark plugs and wires if you havent done it in a while. Were you planning on doing the balancer belt also? If not, you should definetely consider it.
Old 07-31-2004, 11:46 AM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Tranny oil is 30K is I remember correctly. So you can do that also. That is something you can do by yourself easily.
For Sale 98 Eclipse GS, 5 spd
Old 07-31-2004, 01:03 PM
oxygen800r's Avatar
the fluids and shit i'll do.
it's cheaper and less work for me to let them do the timing though.
plugs and wires were swapped out at 50k, so maybe another 5k before i swap them out again.
anything else i should be doing?
Old 07-31-2004, 04:30 PM
AF - Advisor
tbelt, autotensioner, tensioner pulley, ildler pulley, balance belt, bbelt tensioner pulley, water pump.
Kevin Jewer
Old 07-31-2004, 05:06 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
well, here. check this out.
http://cgi.ebay.com/ebaymotors/ws/eB...category=33625
spark plugs & wires, unless you have a good set already. flush of fluids, oil change, brakes, compression.
DSM geek
Old 07-31-2004, 06:25 PM
ashah000's Avatar
Fuel filter
Old 08-01-2004, 07:31 PM
dsmodder dsmodder is offline
Send a message via AIM to dsmodder
the fuel filter is a pain in the ass. make sure you go with the OEM or at leat napa. the only problem i had was with the lower line (IN). it leaked so i tighted it and that didnt work so i pulled it off and put a 2x4 under the line to make sure the male and female (nipple) connected tightly. no leaks after that. oh then remove the 2x4
Old 08-01-2004, 07:32 PM
i cant spell
Old 08-02-2004, 02:21 AM
AF - Advisor
Most dealership techs wont even change the filter. So if you pay to have it done, put a mark of some sort on the old one so you'll know if it was changed. They only get paid like .2 hours to swap that, and it takes forever. So they dont do it.
Kevin Jewer
