Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 07-31-2004, 06:57 AM
sereikastamper sereikastamper is offline
1998 4 Runner Timing Belt
We are in the middle of changing out the timing belt on our 4runner and were wondering is the crankshaft bolt a left hand thread? We cannot get it to budge and were wondering if we are tightening instead of loosening it??? Anyadvice on how to get it off would be greatly appreciated! Thanks
Old 07-31-2004, 10:30 AM
trx125 trx125 is offline
right handed thread use long handle breaker bar and brace against driver side frame rail dissconnect coil wire so engine wont crank anf then bump starter over a couple times should break bolt loose engine turns clockwise so breaker bar should rest on top of frame. hope this helps.
Old 07-31-2004, 10:31 AM
Thanks so much!!!
Old 08-08-2004, 03:03 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 1998 4 Runner Timing Belt
Good idea!
Old 08-09-2004, 08:57 PM
Busted knuckles=Great wisdom and redneck engineering
Old 04-09-2006, 04:16 PM
flip1234 flip1234 is offline
Helped out my neighbour who has all the tools. Impact Gun and all and couldn't get it to budge until he tried this method...............It worked and he now owes me a fishing trip. This was a 1992 4runner
Thanks
Old 04-10-2006, 01:19 AM
4Wheel's Avatar
4Wheel 4Wheel is offline
AF - Advisor
I have a "calibrated" piece of angle iron with two holes drilled in it. That comes to rest on the blacktop, or frame, then I have a half inch breaker bar with a "cheater pipe" slipped over the end and it snaps right off. I also use throw-away bolts to mount the angle iron, they usually bend slightly.
Not too sure about putting that much torque through the starter gear reduction or the starter drive gear and ring gear on the flex plate.
You still need the "right" tools to torque it back correctly.
