Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 07-31-2004, 03:16 AM
mrchris1979 mrchris1979 is offline
mini-me d16y8 head
I've seen posts around regarding sohc vtec heads on d16a6 non-vtec blocks (mini-me) that require the removal of the oil control jet on the d16a6 block using the d16z6 head. I a plan to use the d16y8 head instead but I'm not sure to remove the jet using this head. The heads function the same so I'm assuming the oil jet will need to be removed for proper operation of the d16y8 head. I Just need another opinion or knowledge of someone that has done a similar swap. Thanks
