Old 07-30-2004, 11:06 PM
smokeymicpot smokeymicpot is offline
Send a message via AIM to smokeymicpot
need help car smokes out intake
ok heres my problem i just changed the clutch and toke out the disb and toke out all the wireing and put it all back in and put the disb in and win i try start it and win you go to turn it on its sounds its just spining the motor and than you hear this backfire throw the intake and than you see smoke come out of it.
what did i do wrong?
the disb looks wired win you try to turn on the car it kinda looks like its turning or something never seen that before
how do you tell win the motor is tdc or top died center?
Old 07-31-2004, 02:16 AM
please help i have try'd alot of things i have check'd spark.
i try'd my best to eye the piston to see if its top died center and still nothing.
Old 07-31-2004, 05:52 AM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
you probly just didnt put the distributor back on in the same position. Loosen the 3 bolts holding it on and turn it till the car sounds like its running good. Take it for a drive after that then come back and thank me Hope it works...
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 07-31-2004, 09:33 AM
civic_boy91's Avatar
civic_boy91 civic_boy91 is offline
Send a message via AIM to civic_boy91 Send a message via Yahoo to civic_boy91
Did you put it 180 degrees off? When I took mine i did that by accident.
You didn’t take off the rotor did you? If not than it could be way off...or you but it back on 180 degrees off...its really easy to do if your not paying attention.
_________________________________http://VelocityFactor.com________________________________
1990 si hatch
b20b si tranny
megan race header 2.5 custom exhaust
50 shot
integra da rear disk (w/ 4040 valve)
powerslot rotors and barded lines all around
1994 Dx hatch
stock
Old 07-31-2004, 10:33 AM
Hybrid1990crx's Avatar
Re: need help car smokes out intake
The rotor can only go on one way, so i dont think its that, unless it fell off. It definetly sounds like timing. When we were trying to get this old POS jetta to start we had the firing order wrong and it backfired so hard it kicked the intake of the TB.
Old 07-31-2004, 10:59 AM
Hybrid1990crx is the screw hole on your dizzy going all the way through??you know the one that holds on the rotor.
i think my dad tapped it all the way through and thats how you would get it wrong on "my dizzy" i dont think they came like that...sorry i forgot...
and if he took off the whole distributer there are two prongs coming out of the back... he could have easly put it back in 180 degrees off(maybe he turned it when it was out?)
1990 si hatch
b20b si tranny
50 shot
1994 Dx hatch
stock
Old 07-31-2004, 11:41 AM
ok well i have been tryig puting the block at tdc and win it looks like it the disb up and down could i have it at the wrong 180 or something easy that im not thinking of?
it sounds way off
Old 07-31-2004, 03:02 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
set the block to tdc. now pull off ur cap.
the metal prong on ur rotor should be pointed to the number one spark plug prong on the cap...which is the bottom left corner if you look at it from the passenger side fender. if it's pointed to the number four plug....u put it on 180 degrees backwards..100% sure thats ur problem
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 07-31-2004, 03:36 PM
the problem was i wasn't getting it to tdc as close as i thought i was but it works now and thanks for all the help
