Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 07-30-2004, 10:38 PM
preludicris96's Avatar
preludicris96 preludicris96 is offline
Send a message via AIM to preludicris96
autometer oil pressure gauge help
hey this is the second spot i placed this post to try to get some more exposure...
my autometer oil pressure gauge stopped working on my lude. I didnt install it so im not familiar with it. What should i look at to see why it isnt working. It just reads 0 now. I know there is oil pressure too, so dont anyone be funny about that.
any help is appreciated.
thanks
www.cardomain.com/id/thasandman203
Old 07-31-2004, 03:27 PM
boosted k20's Avatar
boosted k20 boosted k20 is offline
i dont know how the gauge is connected it, so im not familiar with it, niether am i familiar with how to correctly connect a oil press gauge. but from what small knowledge i have, i think the signal for the oil pressure is connected next to the sensor by the oil filter. check to see if the wiring came loose from there. check out all the wiring on the gauge too to see if any wire is not connected
www.MEDIUMRACING.com
Old 07-31-2004, 10:05 PM
I checked the wiring, the wiring on the actual gauge iteself is fine, and it is wired to something that looks like a small filter on the oil ascending unit. The wire had a small burn mark on it where it looked like it had touched the manifold, but it was barly burnt through the plastic, it touched the actual metal part of the wire a tiny bit. I cut that part off and spliced the wires back together but it still does not work. Do you guys think its the gauge or the ascending unit or somthing else??
