Old 07-30-2004, 09:31 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Dress up kit.
sence i have my injen intake, fipk, dejon uicp, 1g bov, mbc, boost gauge, & a pillar coming. i've got the need to do more at the same time. so i bought a Spectre red hose kit with
4.5 feet Upper Radiator Hose Covering & 2 Red Pro Hex Fittings
12 feet Heater hose covering & 4 Red Pro Hex fittings
4 feet fuel line covering & 4 Red Pro Hex fittings
3 feet vacuum line covering & 4 shrink sleeves.
i was wondering if this will be enough to cover all my hoses. i want to get "everything" that has a black hose comming or going.
im also going to give it a shot with painting my Valve cover Red with that high temp spray paint from autozone. are their tourque setting for the valve covers on a 2g 4g63? or can i just bust them loose, and use a regular ratchet to slap it back on tight?
DSM geek
Old 07-30-2004, 09:43 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Re: Dress up kit.
Use 1200F paint. Loosen them with whatever... make sure you use a torque wrench when putting it back on otherwise you will crack it.
BTW how much did that kit cost.. off ebay?
For Sale 98 Eclipse GS, 5 spd
Old 07-30-2004, 10:12 PM
Re: Dress up kit.
18.99 + 6 shipping ups
what are the touqure specs on the valve cover..
DSM geek
Old 07-30-2004, 10:53 PM
Shpyder's Avatar
Shpyder Shpyder is offline
Moderate moderator
Re: Dress up kit.
Dont know, but a $15 Chiltons manuel does. It has everything in it.
The daily driver. The weekend cruiser. The lazy shop hog.
Old 07-30-2004, 11:28 PM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
Re: Dress up kit.
i have that book if you want the specs just ask.
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
Old 07-31-2004, 12:50 AM
joemathews's Avatar
joemathews joemathews is offline
Re: Dress up kit.
Tq. the valve cover bolts down to 32 in. lbs. NOT 32 ft. lbs.
I would be very careful doing this. I would use a torque wrench that reads inch lbs., because if you try to estimate 3 ft. lbs. on a torque wrench like mine that measures in units of 5, you can crack the valve cover like ashah said.
I was careful not to tighten them down too far, and I still ended up creating a hairline crack in the corner of the cover. Nothing a little JBweld won't fix though
Also make sure to follow the bolt tightening pattern found in the shop manual, or at very least tighten them evenly on all sides, not tightening down the left side bolts, then the right (duh...just thought I would remind you ).
1996 Eagle Talon
