Old 07-30-2004, 07:10 PM
travs94s10 travs94s10 is offline
Question windshield wipers work occasionally
Please help with my first vehicle, I have a 94 S10 with a windshield wiper problem. I checked the wires and I have power and you can hear the moter huming but the wipers do not move. Please help
Old 07-31-2004, 07:36 PM
chevdave chevdave is offline
recall?
My '97 s10 wipers had dealer recall work done (free). They would just stop working, but only when it rained. Maybe yours are recalled also??
Old 07-31-2004, 09:03 PM
95silverado 95silverado is offline
Try tapping on the wiper motor. If the wipers start working, the circuit board under the plastic cover has loose connections where the contacts from the plug goes thru the board. Unplug the motor plug and resolder the contacts.
Old 08-08-2004, 07:04 PM
dcoffey dcoffey is offline
Re: recall?
a LOT of s-10 windshield wiper computer boards were recalled. I took my truck in for it, and they tried to charge me, but I had the recall notice and after an hour of arguing they finally caved and fixed it free.
iirc the recall spanned several years worth of s-10s
Old 08-12-2004, 12:34 AM
Re: Re: recall?
PS I used the GUVERNMENT recall notice on them, it is available from a website, took mine like 4 months to get a copy of it...but the windshield wiper compter on s-10s IS recalled and you should get it fixed FREE.
DO NOT LET SOME SHIT DEALER TELL YOU OTHERWISE AND TRY TO CHARGE YOU 150$ LIKE THEY TRIED TO CHARGE ME. I PRESENTED THE GUVERNMENT DOCUMENTS AND THEY CAVED, IT IS MANDATORY THAT THIS BE DONE TO ALL S-10S on RECALL NOTICE.
WINDSHIELD WIPER COMPUTERS ON OLD s-10s ARE RECALLED DEALERS *********MUST********* replace them FREE.
I will try to post the URL to recall info that you can present to dealer for free repair.
Old 08-15-2004, 09:54 AM
smokey041369 smokey041369 is offline
Re: windshield wipers work occasionally
the wiper board new is only 85.00
Old 08-28-2004, 09:22 AM
expat101 expat101 is offline
Hi - did u find the URL on the dealer recall (faulty wipers on S-10) ??
rgrds,
ac
Old 10-15-2005, 11:05 PM
eti engineer's Avatar
eti engineer eti engineer is offline
windshield wipers
I pulled out the printed circuit board -- no easy task -- and resoldered the five connections to from the plug to the circuit board. The solder there is weak and it cracks. The wipers and washers have been working fine since.
There are many S-10's, Astros, etc., which use this same setup -- my neighbor has one. I did the same thing to his after he had taken it to a dealer about three times and he has had no problems ever since.
In the case of the motor humming and nothing happening, it sounds like the linkage has come loose from the ball on the crank connected to the motor shaft. Chevy uses a cheap plastic insert that once removed, or after it has some wear on it pops off. I made a copper wire collar to go around the flange on the bottom of this plastic piece, and mine has not popped off since.
Later..
eti engineer
Old 10-16-2005, 05:20 AM
thanks for info - actually fixed it months ago by buying the circuit board ($30) and replacing the suspect one - took 30 mins, and no problems.
the non-working wiper arm: removing the wiper arm showed that it has a tapered plastic insert, which matches a splined 'drive' shaft. This must be a 'fail-safe' design, to prevent the motor overloading if the wiper blades can't move - as when frozen to the glass. All that was necessary, was to scrape the plastic out from between the metal splines, and tighten up the arm until the splines bit into the plastic again - easy when u see it.
with rgrds,
expat101
