Old 07-30-2004, 07:00 PM
aikahi118 aikahi118 is offline
1987 cherokee air filter soaked w/ motor oil
Just bought a 1987 jeep cherokee w/ a 4.0 inline 6 cyl. Runs great 130,00 miles. There is oil leaking all over th right side of the engine. Inside the airbox the air filter was soaked w/ oil.
Went to local shop they siad a clogged pcv hose was causing this. Any ideas on how to cure this.
Old 07-30-2004, 07:30 PM
caddy94 caddy94 is offline
Re: 1987 cherokee air filter soaked w/ motor oil
carbon builds up under the valve cover and gets into the vacuum line ,should remove valve cover and clean out ,replace and install new vacuum line should help.
Old 07-30-2004, 10:40 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Try the search function for this problem. Theres about 50 threads for the same problem. All 4 L engines do this eventually, it seems.
Old 07-31-2004, 02:33 AM
mansjeep mansjeep is offline
Send a message via Yahoo to mansjeep
Re: Re: 1987 cherokee air filter soaked w/ motor oil
Sorry for my ignorance, but where is the "valve cover"? Is it the one covering the cylinder head (a.k.a rocker arms cover)?
Old 07-31-2004, 05:10 AM
yes the rocker arm cover big long thing on top of the engine it will have small plastic line going to the back of it near the fire wall thats the one that will be plugged I just replaced mine with small rubber hose that you can get from any automotive suppply store
Old 07-31-2004, 01:16 PM
Edbrooks Edbrooks is offline
On the valve cover there are two hoses. The one at the front of the engine is to let fresh air into the engine. The one at the rear is to allow vacuum to suck fumes from the engine into the manifold. The rear hose comes from a disk that has a 2.8 mm diameter 'metered' orifice. This hole becomes plugged. When it does, the oil fumes that result from engine blow-by now can escape only through the front hose and into the air filter, and by blowing past seals, such as the rear engine seal, or around the valve cover. Remove the vacuum hose, remove the orifice disk and clean the hole (drill it out if necessary) This will solve the problem.
Old 09-02-2004, 12:55 PM
jeepfreak32 jeepfreak32 is offline
Whoa..whoa..whoa...you don't have to remove your valve cover because of this problem. It's the CCV hose that is located on the top(toward the firewall) of the valve cover. It's thin and plugs into the intake manifold. It's clogged and needs to be cleaned!!! Take the hose off and run some brake cleaner in it. I used some safety wire and ran it through the hose. It did the trick and my air filter is oil free!! I hope you got this in time!!!
Old 09-05-2004, 04:27 AM
i just took the hose nearest the firewall off sprayed some carb cleaner inside the tube and changed the air fil;ter so far so good
Old 09-05-2004, 09:02 PM
viper1861 viper1861 is offline
There is a soft fix for this. The rubber gromet that fits into the valve cover and plastic tubing that connects has been enlarged. Of course you will pay a premium at the Chrysler parts house. I thinks its normal for these in-line 6's to asperate some oil into those lines. At the price of $40 it might be worth it to clean the lines instead of buying a new kit for which there are 2 and both are priced at approx $40 each.
Old 09-07-2004, 12:22 PM
Eric63 Eric63 is offline
This article here should have what you need:
http://www.off-road.com/jeep/cheroke...ltr/blowby.htm
