Old 07-30-2004, 05:09 PM
SlowPokeGSX SlowPokeGSX is offline
DSMLink back to stock
I know this is a silly questions, but in order to go back to stock form DSM link, do I just need to swap out the Eprom ECU to a stock ECU?
Any help would be very much appreciated.
1997 Eclipse GSX: AGP 50 trim, Tial Wastegate, HKS 264/272's, Denso 660's, DSMLink, AGP Race FMIC, Dejon Intake, Apexi cat-back, and some other stuff.
2003 Mazda Protege5: SR Motorsports cat-back. (Wife's Car)
Old 07-30-2004, 05:36 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: DSMLink back to stock
go back to stock? meaning defualt ecu settings with default injectors? if thats what your asking. disconnect the battery for 5-10 sec. everything will reset just the way it was shipped to your door.
DSM geek
Old 07-30-2004, 10:02 PM
dupeto_e's Avatar
dupeto_e dupeto_e is offline
i think that he needs to change only the EPROM chip. i believe thats all( and reset the ECU ofcourse)...
[IMG][/IMG]
Old 07-30-2004, 10:17 PM
re-socketing the factory rom chip just puts the non-tuneable rom chip in. if he resets the car buy disconnecting the battery and hooking it back up, the cars factory settings will be there. its designed that way so if you fuc* up, all you have to do is disconect the power to have the default factory setting.
DSM geek
Old 07-30-2004, 10:56 PM
kjewer1 kjewer1 is offline
AF - Advisor
Not in every case. DSMlink chip is shipped with certain defaults in it, not the stock defaults. For example, your chip could be setup to default to 660 injectors, inverted cas, 310 deadtime, and 900 rpm idle. Etc. You could just set all the sliders and such back to stock though. Timing and fuel sliders to zero, deadtime zero, reset rev limits etc.
To go back to stock just put the stock chip back in. Should take a whole 10 minutes to do. DSMlink does send back the stock chip in an antistatic chip box just for this purpose. Of course to go COMPLETELY stock, you want your stock ECU if your car is not a 95. I Cant see that being necessary though.
Of course if you have larger than stock injectors you cant do any of this unless you also swap the stock injectors back in.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 07-30-2004, 10:59 PM
why are you doing that? just curious. are you going to sell the dsm rom chip? why are you taking it out?
DSM geek
Old 08-01-2004, 06:16 PM
Sorry for not keeping up with my own post. I was thinking of putting my car back to stock to sell it. I have decided to leave it modded, because I can most likely get more for it. Thanks for the advice and if anyone in AZ wants a turn key 11 sec. car let me know.
Thanks,
Old 08-01-2004, 07:28 PM
no, but the dsmlink chip would be steller. how much?
DSM geek
