Old 07-30-2004, 03:56 PM
enslaved87 enslaved87 is offline
Angry s10 wont start - not getting fuel
Ok guys i REALLY need help here. 88 s10 2.8l tbi. the truck sat all winter without being started just to let you know. If i use starting fluid it fires right up then dies. So the ignition is fine. There is no stream of fuel comming out of the injectors. I pulled off the fuel line and there is barely any fuel being pumped. yes I made sure it had gas . When i feel the injectors after cranking it over, the injectors become damp with fuel, but they do not squirt/atomize anything. i changed the fuel pump relay with the relay next to it, and that did not help anything. I noticed that the oil pressure switch plug had a broken wire and was hanging(not plugged in). So i splicced it back together and plugged it in. Still nothing. so, any ideas guys? i REALLY appreciate any help!!!
Old 07-30-2004, 07:54 PM
Pamsdad Pamsdad is offline
You need to find out if you have fuel pressure. A gauge must be put in-line to check this. Then you can determine if your pump is any good.
When you turn the key to the ON position, do you hear a slight buzzing noise coming from the back of the truck?
97 Chevrolet CC Dually
00 Blazer
Old 07-30-2004, 09:12 PM
Re: s10 wont start - not getting fuel
Heh, there is NO pressure, the pump is not engauging. I pulled the rubber fuel line off and let it dangle. Nothing is comming out. So is there a way to manually turn on the pump to see if its ok? or must i drop the tank and check it that way.
Old 08-05-2004, 08:47 PM
Unhappy
so nobody here has any help? this forum is useless
Old 08-06-2004, 12:13 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
nice attitude bro. People really want to help an impatient child.
How about your pull the fuel line going from the tank to the fuel filter and see if you get any pressure when you put the key to the ON (not start) position.
If there is flow, your fuel filter is clogged, replace it.
If not, your fuel pump fuse is blown, your fuel pump relay is blown or your pump is shot or has a bad ground.
Old 08-06-2004, 09:31 AM
Re: Re: s10 wont start - not getting fuel
HAH! ok BRO! if you would open your eyes and read... i've already did that. AGAIN, if you would read... i was simply asking, is there a way to manually jump 12v to the fuel pump? and btw, there is no fuel pump fuse. just ecm. so if anybody has some helpful knowledge... please indugle me.
Old 08-06-2004, 04:04 PM
BlazerLT's Avatar
AF -Advisor
AGAIN smartass, get your fuel pump checked out.
AGAIN, I did read your post.
AGAIN, guess you are too smart and have this covered.
Old 08-07-2004, 02:41 AM
lowS-DIME lowS-DIME is offline
if you have like... 100k miles... i would just expect it to be your fuel pump... chevys are notorious for them goiing out at about 100k
plans for my new car....
