Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 07-30-2004, 02:52 PM
90sr20det240 90sr20det240 is offline
Question tach problems need help
i have a 90 240sx with an sr20det swapped into it, my tach now no longer works and i have the cluster from the 180sx that goes with the sr20det, additionaly i have a cheap sunpro tach i figured would be easier to hook up for now, but i'm not real formiliar with direct coil ignition systems, i need any info that would help me get either tach working cause i need a tach
and i have already tried to search and havn't found anything
thanks
Old 08-01-2004, 05:42 PM
winstonusmc's Avatar
winstonusmc winstonusmc is offline
Re: tach problems need help
I did the SR swap in an 89. You have to make sure the tach wire is attached to the computer, not to where ever it goes in the KA24e. I had to move the wire to the computer harness to pin 3 (third pin on the top from the left, in the big pin section) it is a yellow and red stripe wire. If it alreadt there, make sure your tach is right. The 180sx came with two motors, CA18DET and SR20DET. The one tach wont work with the other. The CA tach has a dashed red line from 7000-7500 rpms then a solid one from 7500 on. The SR tach has just a solid line from 7500. If you have any more questions just e-mail me at [email protected]
SR20DET RPS13
3" Trust Downpipe, Catco Cat, RS*R ExmagII Catback
Z32 Brakes, Tomei Technical Traxx LSD
Blitz BOV
