Old 07-30-2004, 01:32 PM
sLADe781 sLADe781 is offline
Loose Door Handle
Okay, so my door handle is a little loose on my driver's side. The passenger side is nice and tight but I can't move the handle on the driver side up and down. Is there any way I can make it so that it doesn't move?
Old 07-30-2004, 02:11 PM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
Re: Loose Door Handle
mine is loose also
Old 07-30-2004, 02:16 PM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
Check for a missing screw in the doorjam at handle height. It took me 6 months to figure out why mine was loose...10 seconds to fix it.
Kris
2012 Genesis Coupe 2.0t
Old 07-30-2004, 04:09 PM
Doorjam....do you mean the side panel of the door? Because I don't know which screw you're referring too....
Old 07-31-2004, 01:08 AM
Kris_873 Kris_873 is offline
mine did that too, check the door jam where it latches. also check the other door jam, that swings open, at the hight of the door handle. there should be a screw, unless its missing like landoAWD said, just tighten it and your problem is fixed.
Old 07-31-2004, 02:19 PM
StealthModifier StealthModifier is offline
hmm both of mine are like that, an have been ever since ive got it
Old 07-31-2004, 04:46 PM
It's still a little loose after tightening the screw but it's better than before. Thanks guys.
Kris_873, what's the "other door jam" that you're referring to? The passenger side?
