Go Back   Automotive Forums Car Chat > Honda > Integra
Old 07-30-2004, 08:19 AM
off_da_wall4u2nv off_da_wall4u2nv is offline
spark plugs
i was looking at my spark plugs and i noticed in one there was oil , is it just a gasket problem thats easy to fix or something worse? anybody know? 1994 automatic honda integra.
Old 07-30-2004, 02:24 PM
sameintheend01's Avatar
sameintheend01 sameintheend01 is offline
Send a message via AIM to sameintheend01
Re: spark plugs
maybe a piston ring.
Clear Corners
Front and Rear Strut Bars
Cold Air Intake with K&N filter
Iridium Spark Plugs
High Performance Plug Wires
High Flow Cat (unistalled)
Cool high/low beam lights
All around slotted and AEM pads
Old 07-30-2004, 10:41 PM
Re: spark plugs
am i able to fix myself?
Old 07-31-2004, 05:09 AM
boosted k20's Avatar
boosted k20 boosted k20 is offline
where is the oil exactly? is it on the tip of the sprak plug (where the sprak occurs) or on the outside portion of it. if it's on the outside then maybe u have a bad spark plug gasket which is located on the inside of the head. if it's on the tip then u might have some bad rings which is alot of work to fix!
www.MEDIUMRACING.com
Old 07-31-2004, 12:56 PM
integralover's Avatar
integralover integralover is offline
boosted is right.
93 teg LS
B20B
ACT Performance Flywheel
AEM CAI
DC Sports Stainless Steel Header
G4 High Flow Cat
GReddy MX Cat Back Exhaust
Skunk2 Racing Chip
Lots of interior goodies
Old 08-01-2004, 03:03 AM
Re: spark plugs
yeah i think its on the outside. so i would have to take my head off and replace it right? when putting the head back on what all do i need to do? just put it back on and torque it back down?
Old 08-01-2004, 09:53 AM
No no no no noooooooo. U dont have to take the head off to replace the O-ring/gasket for the spark plug. u need to remove the valve cover. im guessing u have a LS. take the valve cover off and replace the o-ring/gasket then reinstall everything again.
heres a link on how to remove the valve cover and reinstall everything back in the right place
http://65.54.246.250/cgi-bin/linkrd?...goto%3dnewpost
Old 08-01-2004, 10:18 AM
yes only the valve cover. get a valve cover gasket kit. you can get one from a local automotive shop. they come with all the gaskets you need to do the job.
93 teg LS
B20B
AEM CAI
G4 High Flow Cat
Skunk2 Racing Chip
Old 08-01-2004, 10:56 AM
Re: spark plugs
sorry i meant valve cover. thanks
