Go Back   Automotive Forums Car Chat > Honda > N2O | Turbo | Superchargers
N2O | Turbo | Superchargers Tech forum to assist in Honda/Acura Performance.
Old 07-30-2004, 06:20 AM
flipk flipk is offline
Send a message via AIM to flipk
better setup for Integra. ( DC2)
what is a better setup for a "DC2" Integra?
GSR with turbo, LS with turbo, or LS/VTEC with turbo? i also heard that LS block (B18B1) with GSR head is also good for turboing. is this true? post your advice.
Old 07-30-2004, 04:22 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
i would go with a gsr turbo if it were me
Team Lonely Drivers
Old 07-30-2004, 04:45 PM
94tegRS's Avatar
94tegRS 94tegRS is offline
Re: better setup for Integra. ( DC2)
a B18B1 with a GSR head would be LSVTEC.
whats better? boosted GSR, boosted LS, boosted LSVTEC, but I also heard a LSVTEC was good to boost.
well, I have no oppinion since ive not done either of the 3 but I did see a daily driven 5g hatch with a turbo LSVTEC, now I dont know how built it was but on slicks he was running low 11's. had full interior and all.
current
-84 datsun 720 4x4(2nd time)-93 accord-90 camry V6-90 warrior-94 300ex
history:
-01 R1-04 daytona 600-94 teg RS-95 teg LS
-91 teg RS-92 teg GSR-94 civic CX hatch (3 times)
-94 civic DX-96 civic HX-97 Accord LX-72 superbeetle
-74 beetle-84 silverado-66 c10-74 maverick-78 280z
-84 200sx-86 tercel wagon-95 mustang V6
Old 08-08-2004, 08:21 PM
Rating's Avatar
Rating Rating is offline
Send a message via AIM to Rating
I Love My 94 Turbo Gsr
Im not proud of my car because its fast, Im proud of it be cause I built it that way.
Old 08-08-2004, 09:00 PM
WhiteLine Civic WhiteLine Civic is offline
if I were you I would do LS turbo, I put a TDO5H on a friend of mines LS hatch and he put down 250hp to the wheels at 10 psi. I pust a T3/T4 on an LS del sol and he put down 280 hp to the wheels at 10 psi. DOHC vtec is fun but I wouldn't turbo them because when Vtec kicks in your going to loose boost because Vtec means the exaust valves are wide open so your turbo will be staved of exaust gasses.
Old 08-08-2004, 09:33 PM
94tegRS's Avatar
vtec doesnt leave the xhaust valves wide open if thats what your saying? if it did the engine wouldnt run, there is overlap if this is what you mean. and if the valves were wide open, it wouldnt starve the turbo of exhaust gases anyways, theyd be wide open and still giving the turbo what it needs to spin. I will bet if you bost a LS to 10 pounds, then leave EVERYTHING the same except bolt a GSR head to the LS blcok and run same boost and all the VTEC will win.
current
history:
Old 08-09-2004, 01:11 AM
whiteline, do you have any idea on how vtec works ? a gsr motor will make more power then an ls, and an ls vtec will make more power then a gsr is built right. but unless the lsvtec is built right its not reliable.
if it were me id go gsr so its all stock and dont gotta worry about any kind of frankenstein build
Team Lonely Drivers
Old 08-09-2004, 01:31 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: Re: better setup for Integra. ( DC2)
How much longer will it be boosting before he melts a piston? Doesnt matter what you boost on. DOHC, SOHC, VTEC non VTEC, B16a, B18c1, B18b, etc,etc,etc. Do it right the first time. Get some engine management at least.
Maybe when VTEC kicks in, there wont be anymore compression left
Here ya go Whiteline, it gives you a VTEC visual.
http://www.honda-marine.com/v_vtec.htm
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
