Go Back   Automotive Forums Car Chat > Honda > Integra
Old 07-30-2004, 04:45 AM
off_da_wall4u2nv off_da_wall4u2nv is offline
distributor?
i was changing my rotor the other day and i noticed when i pulled the distributor cap off there was oil leaking somewhere from out the bottom. anybody know how this could of happened and is it a do it yourself repair? anybody know? 1994 automatic honda integra.
Old 07-31-2004, 12:58 PM
integralover's Avatar
integralover integralover is offline
inside the distributor or on the outside of the distributor?
93 teg LS
B20B
ACT Performance Flywheel
AEM CAI
DC Sports Stainless Steel Header
G4 High Flow Cat
GReddy MX Cat Back Exhaust
Skunk2 Racing Chip
Lots of interior goodies
Old 08-01-2004, 03:00 AM
Re: distributor?
its coming from within the distributor.
Old 08-01-2004, 09:07 AM
gmoorhouse gmoorhouse is offline
What are the odds of getting a bad dizzy?
My car worked great but died at a stop light......a shop replaced the dizzy......they said it ran for a "long" while. I went to pick it up the next day it died within 20 mins on the way home.......now it starts for 10 mins at max then dies (like an on/off switch)......New battery, new plugs, new dizzy. The car seems to die once it gets to a certain temp....but now I seen a few other things......the radiator is getting low but the reserve tank stays near high.....there was also two wires together that look like they need to be grounded which were around the dizzy below near the lower radiator hose. The car pulls the ECU code 14=ignition output signal but I've been told that doesn't mean the problem but just the ECU says it died because of it died but why did it die.
Any help.
Old 08-01-2004, 09:37 AM
Re: distributor?
no absolutely no help at all but thanks how does that tell me why there is oil leaking from my radiator?
