Old 07-30-2004, 03:38 AM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
Unhappy Update: car runs again... just doesnt move! lol Big thanks goes out to 95 GSXracer!!
well the car is back up and running although i cannot seem to get the clutch to dissengage with the motor running! yes its adjusted just fine and the system has been bleed... goes into gear just fine while its running up on the hoist, can get it to go through gears but when i apply the brakes with it in first and the clutch in the motor stalls out so i know the clutch isnt dissengaging! so did a little RESEARCH <--- WHAT EVERYONE SHOULD DO BEFORE THEY ASK A QUESTION! and i came up with a bunch of great info from many of Kevins posts! THANK YOU KEVIN... i dont know where i would be without you, probably still under the car wondering why the fuck my car wont go into gear! lol anyways taking the tranny off in about 1/2hr to inspect the throw out bearing but so far from what i can see it looks to be fine... my guess is that the clutch fork is hitting the side of the bellhousing causing it to not allow the clutch to dissengage all the way! anyone else that has this problem... here is the fix: gotta give kevin all the credit he deserves!!! this info has been found in this thread if anyone has any further questions... http://www.automotiveforums.com/vbul...d.php?t=186286
Originally Posted by 95 GSXracer
Its alos important to note that as you machine more and more material off a flywheel, and use stronger plates, some travel of the slave is lost. The clutch throwout fork can hit the side of the hole it comes through in the bellhousing before the clutch is fully disengaged. If you find this is happening, or you know the flywheel is getting thin (the firction surface is level with the body of the FW), shim out the ball stud the fork pivots on. Just remove it, and put a washer behind it. That will move the whole fork closer to the plate, getting you some travel back. Taboo makes a 1/4" longer slave rod, but I've never used one.
thanks a lot man... this seems to be the problem and hopefully will be the fix, i might just get a new throw out bearing anyways since i am goin to have the tranny of anyways! hopefully she will stay together long enough to make it through sunday... Import race day at the local track so i am goin to see what times i can get... shit it will be the first time i have had it at the track so hopefully i dont kill it again! i'm gunna trailer it there just incase. gotta think ahead. i'll let you all know the outcome... probably wont be back on here until late tomorrow (friday) night! hopefully all goes well! i'm out... peace~
Jake
~EclipseRST
Old 07-30-2004, 11:03 AM
guitarXgeek's Avatar
guitarXgeek guitarXgeek is offline
Send a message via AIM to guitarXgeek
Good luck, Jake And be sure to tear up some honduhs for us!
95 GSX
DSMlink, "50 Trim", and track times coming VERY SOON!
Old 07-30-2004, 01:21 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Update: car runs again... just doesnt move! lol Big thanks goes out to 95 GSXracer!!
I hope that fixes it I always keep a washer behind the ballstud on every tranny I install now, it always helps. And if it shims it out too much, there is plenty of adjustment at the pedal rod in the opposite direction... Hope it works out for you. And replacing the TOB is certainly a good idea while you are in there, only ~25 bucks.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 07-30-2004, 07:10 PM
george536's Avatar
george536 george536 is offline
Good Luck!!!
Old 07-31-2004, 09:41 AM
EclipseRST's Avatar
Banned
well after a fun morning yesterday of removing the tranny and checking everything it ended up being the release fork was hitting the bell housing... so shimmed it out a little wit a 1/8th" washer, replaced the TOB just to be on the safe side and put the car back together... started at 6am, had everything off by 7am, went to parts store and to mcdonalds for breakfast, back to the shop by 7:45am, car back together and off the hoist by 9am! that has got to be one of the fastest removal and reinstallations i have ever done on a tranny! i sure hope its the last time i have to do it for awhile! hopefully i dont break it tomorrow!
Old 07-31-2004, 10:22 AM
AF - Advisor
Nice work.
Kevin Jewer
Old 07-31-2004, 01:47 PM
george536's Avatar
even had time for breakfast. Im impressed.
Old 07-31-2004, 06:35 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
McDonalds is the DSM'ers allstar chioce for breakfest!
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 08-01-2004, 01:26 AM
george536's Avatar
McGridle is the best. want some rite now.
