Go Back   Automotive Forums Car Chat > Honda > Integra
Old 07-30-2004, 01:55 AM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
leaky rad
well... earlier today, i saw that i had a bit of antifreeze leaking from somewhere... i thought, well crap that's no good, so i took off one of the lower splash guard things and saw that it was coming from my lower rad hose, so i decided that i'd give the old coolant a flush... did that, everything was all fine and dandy until i went to go put everything back together and fill it up... after i had gotten everything good and clamped down, started to fill up the rad and it started leaking from the same place... so i got really pissed off and kicked a wall.. then took everything back apart again... checked it all over with a magnifying glass, and i couldn't see any cracks in the rad or the hose... any idea's what the problem could be?
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
Old 07-30-2004, 02:25 PM
sameintheend01's Avatar
sameintheend01 sameintheend01 is offline
Send a message via AIM to sameintheend01
Re: leaky rad
you said u saw it coming from the lower radiator hose. did u replace that? if u got the green fluid i think u can use a UV light to find the leak.
Clear Corners
Front and Rear Strut Bars
Cold Air Intake with K&N filter
Iridium Spark Plugs
High Performance Plug Wires
High Flow Cat (unistalled)
Cool high/low beam lights
All around slotted and AEM pads
Old 07-30-2004, 02:33 PM
DeleriousZ's Avatar
Re: leaky rad
yeah, i haven't had time to get to that yet... but once i got everything tightened down, it was still comin out fairly quickly... like i'm talking thin flow... it's right where the hose connects to the rad... i know it was sealed down well enough cause i almost broke the clamp tightening it down... we'll see once i get a new hose for it
Old 07-30-2004, 02:40 PM
Re: leaky rad
that's bad...could be the plastic connection on the radiator...that means new radiator.
Clear Corners
Iridium Spark Plugs
