Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 07-30-2004, 12:41 AM
thundley thundley is offline
Send a message via AIM to thundley Send a message via MSN to thundley Send a message via Yahoo to thundley
Unhappy I need the patch for my car so it will stop smoking
I noticed my Town Car Exec smokes white smoke when I first start it.. it is only about 5 seconds. More of a poof of smoke. I also think it does it when I start from a stop..another poof at that time. Any ideas.. do I need a tune up or what?? I just bought this car about three weeks ago...
Terry
93 Town Car Exec
260,000 miles and going strong..
Old 07-30-2004, 01:39 PM
Towncar's Avatar
Towncar Towncar is offline
Re: I need the patch for my car so it will stop smoking
1st guess would be, you need new Valve Stem Seals.
-Steven
1996 Town Car, Cartier
Old 07-30-2004, 10:21 PM
Should I be ready to lose an arm and leg
How much would you think to have this done??
Old 07-31-2004, 02:00 AM
Towncar's Avatar
For a shop to do it would be $700 to $1200 and up depending on who you ask, and the method the use to do it.
The methods would be 1) remove the cams and replace the seals 2) Loosen the cams enough to remove the springs which would be intensely more difficult 3) remove the heads and R&R them.
If you chose to do it yourself you would most likely attempt to loosen the cams because there would be less engine teardown ie camchain removal.
The parts themselves would be around $50~$60 including gaskets. All the remaining cost is labor.
-Steven
Old 10-12-2004, 07:17 PM
Mike2755us's Avatar
Mike2755us Mike2755us is offline
Send a message via Yahoo to Mike2755us
Terry
93 Town Car Exec
Hi Terry, i have the same car and had the same smoke until this friend of mine put valvoline 20w50 oil, synthetic oil mix and a bottle of no-smoke made by Bardaul...check it out 170,000 miles and cruising now.
Michael 93' t/c exec.
Old 10-21-2004, 01:01 AM
kittenmueller kittenmueller is offline
Red face same here-1993 tc sign series
Just got this car and it is the first week on the road. Changed all the fluids ( not oil yet) but it is clean. Poofs - just like he says- white- mechanic said to wait out the first tank of gas as we put fuel inj cleaner and do not know how long since the car was ran. So keeping our fingers crossed that is all it is.
Update- yup, just got it back from shop and he said exactly what you did- valve stem seals! Said to just watch oil and let it be unless it gets worse as it seems very minor. So, will not put the cash into it as it is a 93 and not worth putting that kind of money into!
