Old 07-30-2004, 12:17 AM
jgoertz7 jgoertz7 is offline
timing issues?
I swapped a d15b vtec engine in my 88 crx si. It cranks over, but it wont fire up. I know I am getting fuel because I loosened the fuel rail and fuel started spraying everywhere. the distributor is the stock TD-42u which I believe also in on the d16z6. the distributor is new, and I KNOW I am getting spark. The firing order is 1-3-4-2 correct? I am stumped. could this be anything but timing? oh, and one more thing I stayed obdo so I kept the 88 intake so I wouldn't have to fool around with wiring (except the distributor wiring, which I believe is color matched). any help would be appreciated
Old 07-30-2004, 04:47 PM
come on, no ideas? I really need help here
Old 07-30-2004, 05:55 PM
crx hf crx hf is offline
Have you tried that little connector by the starter.Its a little plug if thats not in the car wont start.Also try checking all your grounds.The one by the thermostat is the one that gets me all the time.
Old 07-30-2004, 05:56 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
just because you got fuel to come out of your fuel rail doesnt mean that its getting into the combustion chambers. Could be your injectors or a cloggled fuel rail or something. After cranking it for a while take out a plug or two and smell for the gas. Let us know what happens then we'll throw you some more suggestions ify ou need them
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 08-03-2004, 12:13 AM
the problem isn't the starter because it cranks over. It just wont start.
I am getting fuel into the cylinders, it backfires once in awhile and I get a huge blue flame out the headers cool, yes. supposed to happen, no. any other suggestions?
Old 08-03-2004, 08:16 AM
civic_boy91's Avatar
civic_boy91 civic_boy91 is offline
Send a message via AIM to civic_boy91 Send a message via Yahoo to civic_boy91
um ... the car only has one header...and i dont think it is sepposed to backfire... check your timing one more time..
_________________________________http://VelocityFactor.com________________________________
1990 si hatch
b20b si tranny
megan race header 2.5 custom exhaust
50 shot
integra da rear disk (w/ 4040 valve)
powerslot rotors and barded lines all around
1994 Dx hatch
stock
Old 08-03-2004, 08:24 AM
The distributor firing order is (#1 cylinder at the bottom left) 1,3,4,2, in a counter clockwise motion, looking at the dizzy... good luck
*edit* #1 cyl. is the one all the way to the driver side of the car(only if your in a LHD car...lol)
1990 si hatch
b20b si tranny
50 shot
1994 Dx hatch
stock
Old 08-03-2004, 08:42 PM
Re: timing issues?
okay, so I have the firing order right. hmm.....well, since the d15b vtec is obd1 and I stayed obd0 I am starting to wonder if I just wired the dizzy wrong. I just spliced the same color wires together. Is this wrong?
Old 08-03-2004, 08:58 PM
91civicDXdude's Avatar
Re: timing issues?
you can use OBD1 distributor with OBD0 ECU. the components inside are different.
Old 08-03-2004, 10:57 PM
Re: timing issues?
I know that part. I was just wondering if there is a certain way to wire up the distributor
Old 08-05-2004, 11:15 PM
Re: timing issues?
anyone know anything about wiring up my distributor?
Old 08-06-2004, 01:54 AM
dssmax's Avatar
dssmax dssmax is offline
Re: timing issues?
Hrmm,
have you pulled all the plugs and lined them up then cranked them to see if they are fireing in order?
Is your timing belt on correctly? TDC on the crank and cam are the same?
Was the motor running before you put it in?
MAX
Your Signature
Old 08-06-2004, 09:52 AM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
Re: Re: timing issues?
dang...beat me to it...you ALWAYS beat me to the punch...
Anyway, yah, like dxdude said...you CANT use that dizzy with that ecu. Ur gonna have to convert to OBD1 or swap on and modify the A6 dizzy for that head
Trust us...we know what were talking about (for the most part) and i speak from experience here...
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
