Old 07-29-2004, 10:29 PM
Knight2040's Avatar
Knight2040 Knight2040 is offline
Send a message via AIM to Knight2040
Triple Gauge Pod
hey yall i was wondering where i could get a triple Gauge Pod for my pillar? i tryed lookin on the internet but i could only find double, also do the pillar guages block your vision at all?
1991 Mitsubishi 3000GT VR4 Twin Turbo- Forged Ross Pistons,Forged Crank,Forged and Shotpeened Rods,Stillin DP,K&N FIPK,Greddy Type-RS BOV,Magnacor Wires,Aluminum Y-Pipe,EGR Blocked,All Gutted Cats,Greddy Turbo Timer,Blitz Boost Guage,Autometer A\F Guage,Solid Shift Bushings,Red Top Batt,ACT 6 Puck Clutch,Free Boost Mod,99 Front End Conversion
Old 07-30-2004, 01:16 AM
Hotshot8792 Hotshot8792 is offline
i forgot who sells/sold the whole a-pillar replacement with a 3 gauge pod. I do not know if they still sell them or not. You can always buy a dual and a single gauge pod and put them together to make a triple gauge pod and you wont be able to tell a difference that you did so. And no, it does not block your vision while your driving.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 07-31-2004, 02:15 AM
Kris_873 Kris_873 is offline
Re: Triple Gauge Pod
check out
http://www.midnight-haze.com/interior/gaugepod/
Old 08-01-2004, 10:54 AM
Igovert500's Avatar
blue + red light magnet
http://www.3si.org/forum/showthread.php?t=220656
I was just checking out 3si and someone asked the same question.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 08-01-2004, 12:02 PM
Knight2040's Avatar
thanks guys, but i think i'll go the cheap way and get a dual+single at advanced auto since my freind works there and has discounts
Old 08-24-2004, 01:54 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Personally i absolutely DETEST those gauges on the A-pillar. So i've searched far and wide and found an alternate answer. Erik Gross has custom made a center gauge pod that fits on top of the dash, directly above the 3 current gauges. Check out the pix...pretty awesome.
Here's the link to his site:http://www.team3s.com/~egross/ then click "For Sale!" on the left, then scroll to the bottom.
Enjoy!
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 08-24-2004, 04:11 AM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
That'll probably block your bision a bit, but it'd be awsome to have all six right there.
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
