Go Back   Automotive Forums Car Chat > Honda > N2O | Turbo | Superchargers
N2O | Turbo | Superchargers Tech forum to assist in Honda/Acura Performance.
Old 07-29-2004, 10:22 PM
SlowerCivic SlowerCivic is offline
white smoke need help
Ok I have a problem I just turbocharged my car and put a new turbo on it well I overfilled the oil like almost a centimeter past full on the dipstick and my car is smoking like a bitch but im not sure thats what it is the car is still driveable and its not overheating and theres no check engine code its sounds fine but its just smoking like crazy need help?
157 second quarter mile.
10 min. 0-60
2.7 sec 60-0
79 mpg
Old 07-29-2004, 11:21 PM
performancetuning performancetuning is offline
Send a message via AIM to performancetuning
Same thing happened to my brother on his GST Eclipse it was something with his turbo.
Old 07-30-2004, 01:14 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
white smoke is usually burning water. maybe a blown headgasket.
how much psi you running, whats your engine management ?
Team Lonely Drivers
Old 07-30-2004, 07:05 AM
Re: white smoke need help
well im running 7 now heres what happened I had a turbo on there from an 84 ford well the internals of the turbo were leaking oil real bad but I was really retarded and ran 15 pounds of boost on the stock engine now the engine wasnt smoking before I put that turbo on now Ive bought a brand new turbonetics turbo and I hadnt started my engine up before putting this new one on.Now there is smoke coming out of the engine.Would you suggest I keep an eye on my coolant and all that crap.How hard is it to replace a blown head gasket is it expenisive?
10 min. 0-60
2.7 sec 60-0
79 mpg
Old 07-30-2004, 07:06 AM
maybe i blew it when I tried to run that much boost how can I tell if I blew it or not?
10 min. 0-60
2.7 sec 60-0
79 mpg
Old 07-30-2004, 07:24 AM
ok also it does not smoke unless i hit the gas a little bit,at idle it does nothing,but as soon as i hit the gas white smoke comes out of the exhaust.
10 min. 0-60
2.7 sec 60-0
79 mpg
Old 07-30-2004, 04:31 PM
can do a leak down test
hows your a/f ? whats its at on boost ? how much are you retarding when boosting ?
i think maybe when you boosted that much you might have blown the headgasket
Team Lonely Drivers
Old 07-30-2004, 04:47 PM
boosted_88_CRX boosted_88_CRX is offline
Re: Re: white smoke need help
u ran 15 PSI on a Stock Motor....ohh man.....its for sure ur head gasket...since you blew that one replace it with a cometic head gasket..they can handle higher boost ..not to high tho....12 PSI is good....good thing you didnt blow ur rings and ring lans...cometic head gasket run for 160....then u gotta find someone to intall it...good luck....
Old 07-31-2004, 05:17 AM
kerthizo kerthizo is offline
Send a message via MSN to kerthizo
I've blown a few head gaskets, never one on a turbo car but sometimes if you check the oil you can see the water, or antifreeze on the dip stick if it is blown, and generally the car tends to overheat.
Old 07-31-2004, 06:27 AM
is it hard to replace it,do you have to pull the motor cause I really dont want to have to do that considering I dont have an engine lift?
10 min. 0-60
2.7 sec 60-0
79 mpg
Old 08-03-2004, 11:38 PM
WhiteLine Civic WhiteLine Civic is offline
changing a head gasket is easy, you have to pull off the head the remove all the vac lines from the intake and the rear intake bracket. (I would pull it with the intake on the head.)remove your exaust mainfold, valve cover then take out the head bolts, this is where it helps to have a few friends with you... pull the head out. get the head shaved a a machine shop that should run you around $100-$200, a new gasket will be around $100-$140 for the good stuff. I would put lables on all of the bolts and put them in bags so you don't forget where they go... also you might want to get the block and head built while its at the machine shop... hope this helps
Old 08-04-2004, 10:54 PM
thanks i thought it would be easy to do
10 min. 0-60
2.7 sec 60-0
79 mpg
