Old 07-29-2004, 09:46 PM
BlackShadowTSi BlackShadowTSi is offline
Send a message via AIM to BlackShadowTSi Send a message via MSN to BlackShadowTSi Send a message via Yahoo to BlackShadowTSi
Injectors
I'm planing to buy new inyector for my proyect and i found 4 differet ones I don't know wich one is better for the configuration i will have
I found: PT Lucas 550cc --->$217
680cc--->$280
780cc--->$280
880cc--->$280
Plz tell me wich one should be better for my car, if I put a 16g or 14b turbo not sure wich one I have yet i guess that is a 16g, k&n air filter, Walbro 255 fuel pump, ACT 2600 (I don't want to have the same problem I had with the clutch,I want a strong one now ), Greddy Type-S, Greddy 3" exhaust, 3" down pipe, and I think thats all i can put tell me if i'm missing something
Thanks
Diego Fontán
Eclipse GS-t ==>AWD
12.12 @ 113.xxmph
60' 1.76
Check My GS-T ==> AWD project
car's video: http://cssteam.com/gstx.wmv
At the track: http://videos.streetfire.net/video/aad4c670-6066-44d5-b6f6-c04346cb8407.htm
Old 07-29-2004, 10:02 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: Injectors
550's will be fine for everything but the fastest 16g's... I'd say worry about it when you've got everything up to that point.. including fuel control and a pump. Some EVO 16g owners say they max 550's, so 660's wouldn't be a bad idea if you ever plan on upgrading. If you want to get DSMlink, you can run any of them.
Old 07-29-2004, 10:09 PM
Re: Injectors
I can run 550's without a fuel control, how much $ is it?
Thanks for your help
Diego Fontán
Eclipse GS-t ==>AWD
12.12 @ 113.xxmph
60' 1.76
Old 07-29-2004, 10:18 PM
Re: Injectors
in the ealge i was runnig with the "14b 16g" with the stock fuel pump and inyector but the check engine light was always on the mechanic said that the problem was the ecu , he said that the signal wasn't stong enought, I thought that the problem was in the fuel cause if i'm running a the car with a bigger turbo i should need more fuel in the cylinders, thats my idea and i'm almos sure i'm wrong
Diego Fontán
Eclipse GS-t ==>AWD
12.12 @ 113.xxmph
60' 1.76
Old 07-29-2004, 10:52 PM
JoeWagon's Avatar
Banned
Re: Injectors
no, more fuel means fuel controller. S-AFC2 can only handle 660's I believe. DSMlink can do more.
Old 07-29-2004, 11:05 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Injectors
The key is what fuel you are going to run. With an AFC, you only have 50% adjustment in either direction. 660s will put you around -32%, not leaving much room to lean out on race gas. But its doable. Of course on race gas 550s are more than enough for a 16g. On pump gas and high boost, you'll want the 660s. Also remember that the bigger the injector you use, the more you drop the airflow signal to the ECU, making timing go even higher. I would try to run the 550s unless you think you really need the 660s. Or run the 660s and retard base timing if you have a 1g, or 2g with with 1g CAS.
DSMlink is always the best setup, but at the least, if you have an eprom ECU, get the chip with injector compensation that Jeff O offers at keydiver (http://www.dsmchips.com/). With injector compensation chip, or DSMink, you can run whatever injector you want without bollixing up your timing and risking your motor.
IMO, YMMV, etc
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 07-29-2004, 11:43 PM
Re: Injectors
how should i know if i have an eprom ecu, and my idea is still using this car like a street car during the weeh and for the track on the weekends, so i think that the best is the 550's safer and easyer cause i don't have to change nothing on the timming.
Diego Fontán
Eclipse GS-t ==>AWD
12.12 @ 113.xxmph
60' 1.76
Old 07-30-2004, 12:00 AM
AF - Advisor
Re: Injectors
IF you arent going for big time pump power, then 550s should be the best way to go. Only 95 cars had eproms, so you shouldnt have one, another reason to lean towards 550s.
Kevin Jewer
Old 07-30-2004, 12:22 AM
Re: Injectors
ok, so i will go with the 550's, i have an eprom on the 95 thats nice i allways receive good news of you guys thanks, one of the times i ask about something Jake told me that I had a 14b or 16g when i thought that was the original
Diego Fontán
Eclipse GS-t ==>AWD
12.12 @ 113.xxmph
60' 1.76
Old 07-30-2004, 12:45 AM
Re: Injectors
So you two guys are agree with my list the only thing were the injectors, that kevin allready told me to use the 550's???
Diego Fontán
Eclipse GS-t ==>AWD
12.12 @ 113.xxmph
60' 1.76
Old 07-30-2004, 07:21 PM
JoeWagon's Avatar
Banned
Re: Injectors
I was just saying the bigger the better, but you can only go so big depending on what fuel control you are going to use. Hell if I don't buy 850's for bragging rights.. as long as I invest in DSMlink.
