| 240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all. |
Egr Valve ?
On My 96 Ztt I Can Heard Like An Exhaust Leak On Back Of Engine. I Took It To A Shop And The Guy Said That It Might Be My Egr Valve. How Hard Is It To Work Or Fix This Problem?
Re: Egr Valve ?
There is an EGR (Exhaust Gas Reflux/Recirculation) valve on the back of the engine just under the intake collector. It then comes around into 2 arms underneath either side of the intake collector and then up into the intake collector. This helps to lower the flame temperature of the combustion, which helps reduce NOx emissions. You will definitely *NOT* pass emissions if you take this out.
If it sounds like its coming from the back of the engine, chances are the valve (or pipes) have rusted through or something. Check out the arms to make sure they're bolted onto the bottom of the collector tight, and feel around the arms for cracks/rust. If the arms appear to be alright, its the valve. Replace the valve. You can try taking it off and working on it, but if its rusted through or something, then its just gonna be a waste of time. Oh, and Nice Capitalisation Of All Your Words Btw. ![]() -Mike |
Re: Egr Valve ?
Mikeman, Do You Have More Info On Replacing The Egr Valve In Case Thats My Problem? I'm Plannig On Swapping Out My Down Pipes And Hopefully I Can Kill Two Birs With One Stone.
As For All My Words Been Cap, Thats My Computer Doing It! I'm Just Typing All Caps , Didn't Even Notice |
Re: Re: Egr Valve ?
![]() -Mike |
Re: Egr Valve ?
it's not your computer making just the first letter caps, it's the website.. i guess they thought it would be less annoying instead of having every single letter in caps..
ZedEx Crew Member #61988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc. blown turbo, under construction.. gt35 coming. |
Re: Egr Valve ?
Well I Call Sgp And They Said That You Have To Drop The Trany! Thats Why I Mention My Down Pipes. Buy If You Don't Have To Drop Trany Thats Less Work I Have To Do.
I Wonder Why Sgp Would Drop The The Trany? |
