Go Back   Automotive Forums Car Chat > Toyota > Celica
Old 07-29-2004, 09:14 PM
cvalin cvalin is offline
Best way to get 300+hp from my 3SGTE engine?
I have a stock 1990 celica turbo all-trac that I would like to start increasing the performance on. I am going to pull the engine and am looking to rebuild it with 300+ HP. Problem is I don't want to waste any time or money on products that it doesn't need. Can anyone help me with suggestions as what to do to get the power I'm looking for. I am a big fan of low rpm power so a turbo that spools up quickly is important, any suggestions as to which one to upgrade to or will a retuned stock one work?
Old 08-03-2004, 05:28 AM
nialusa nialusa is offline
Send a message via ICQ to nialusa Send a message via AIM to nialusa Send a message via MSN to nialusa Send a message via Yahoo to nialusa
Re: Best way to get 300+hp from my 3SGTE engine?
Stick with the stock one, they`re OK, a bigger turbo will take longer to get up to speed so increase turbo lag, Start with a superchip or similar. Uprated wastegate for your turbo, this increases pressure, with this you will probably need a bigger fuel pump/injectors but you would have to check on that. You might not get the power you want and maintain the reliablity of the car??????
Old 08-03-2004, 02:36 PM
Cynistah Celica Cynistah Celica is offline
Yow all you have to do is get your hands on a Modified Mag. for the month of August 2004. Centerforce has a 1990 Celica GT 3SGTE in there with 397 whp and they state their upgrades.........take notes!
Old 08-04-2004, 11:57 PM
MR2Driver's Avatar
MR2Driver MR2Driver is offline
Re: Re: Best way to get 300+hp from my 3SGTE engine?
Thats what i'd call BAD advice. 1st of all the stock CT26 doesnt hold boost until redline, an upgrade would be a very much welcome idea. Perhaps a CT20B, or getting your CT26 ugpraded by ATSracing, they have a new upgrade for the turbo that makes it capabel of 300+RWHP.
Also certain T3/T3 turbos with a 46 trim are known to have stock spool up but they can handle the boost more efficiently than the CT26.
You might want to read this power primer for the 3S-GTE written by RickyB... http://www.mrcontrols.com/primers/power.htm
