Old 07-29-2004, 08:25 PM
QuikShifter's Avatar
QuikShifter QuikShifter is offline
Question Re-Calibrate your tach!!
anybody know how to do this, mine is no longer accurate after I did my swap. Has anyone experienced this after thier swap. I had to rely on my timing light for accurate readings during tuning. after it warms-up, the needle sits all the way at the bottom, iam prolly 500rpm off or so. I have looked for another Si cluster(88-89) to no avail. iam also not sure it will behave the same way.I really dont want an aftermarket tach or one from a 90-91, so any helpful suggestions would be kool.
Old 07-29-2004, 08:45 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
Re: Re-Calibrate your tach!!
Stock Tachs are just notoriously inaccurate.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 07-29-2004, 09:06 PM
so any other suggestions besides aftermarket tach. why are they so inaccurate anyway?
Old 07-29-2004, 09:20 PM
aeonsi aeonsi is offline
Re: Re: Re-Calibrate your tach!!
not really, factory tachs use a coil spring and tension to determine the rpms from the tach cable. after 100k or so miles and the coil springs lose their tension. aftermarket tachs pick a signal off the ignition.
hope that helps
Old 07-29-2004, 09:23 PM
viridion viridion is offline
Send a message via ICQ to viridion Send a message via AIM to viridion Send a message via MSN to viridion Send a message via Yahoo to viridion
i have a 88 89 cluster sitting around.. I live in MN and could ship if you want.. PM me if you're interested.
Also... honda tachs are electronic.. i've never actually seen a cable operated tach.
i have no idea why yours would be off besides a different signal from the ecu.
-Josh
B18A into 90 hatch, daily driver
projects:
all kinds of fun and wierd honda projects/conversions,
funnest is SBC into 90 hatch, RWD conversion, turbo400 tranny.. it's a cut and weld thing
Old 07-29-2004, 09:27 PM
do'h woops I reversed the speedo and the tack sorry
Old 07-29-2004, 09:32 PM
does anyone actually have an accurate tach with thier hybrid motor?? if so, is your car a sub 100k mileage car??
Old 07-29-2004, 11:45 PM
krustindumm's Avatar
krustindumm krustindumm is offline
the swap should not have effeccted your tach at all. check your wiring.
91 Civic Dx Hatch
Midwest Honda's MySpace group
Old 07-30-2004, 08:29 PM
my wiring is perfect, didnt even mess with the cluster. I mean, the tach does work, just -500 inaccurate. i'm getting used to it but its a pain when trying to tune the car, and just doesnt look right!
