Old 07-29-2004, 02:07 PM
Dx18704 Dx18704 is offline
Send a message via AIM to Dx18704
Angry Car Won't Start!
Ok well i got a problem here......My car wont start when its hot or humid out it makes a noise like its trying to turn over but it just wont turn over...I know its not the battery because that was just replaced...Any help would be greatly appreciated thanxz
\m/ (-.-) \m/
Rock and Roll will never die
Old 07-29-2004, 02:21 PM
Darb 2k's Avatar
Darb 2k Darb 2k is offline
i had that problem too. i just did a regular tune up and it was fine. i think it were my plugs they were pretty dirty. try changing ur spark plugs. or at least look at them see what shape theya re in
Old 07-29-2004, 02:33 PM
civic_boy91's Avatar
civic_boy91 civic_boy91 is offline
Send a message via AIM to civic_boy91 Send a message via Yahoo to civic_boy91
are you getting fuel? is the pump turning on? to check if the pump is turning on. turn the key to run, dont try and start it tho. for about 2 sec you should here a kinda wine noise...its really quiet so listen. it helps to have the door(s) open (at least on my car it seems louder on the outside). if you can not hear anything it is most likely your main relay...
_________________________________http://VelocityFactor.com________________________________
1990 si hatch
b20b si tranny
megan race header 2.5 custom exhaust
50 shot
integra da rear disk (w/ 4040 valve)
powerslot rotors and barded lines all around
1994 Dx hatch
stock
Old 07-30-2004, 12:20 AM
If it is my main relay is it hard to fix?
any other possibilites of what it could be
\m/ (-.-) \m/
Old 08-05-2004, 11:48 PM
civicwithawankel civicwithawankel is offline
Re: Car Won't Start!
check the distributor cap, rotor, timing, etc
Old 08-06-2004, 12:05 AM
Gitrdone42 Gitrdone42 is offline
Send a message via AIM to Gitrdone42
Im having that same problem with my car but some times it will start but most of the time it dont. but if you find something that helps let me know. thanks
Old 08-06-2004, 05:15 AM
V-K V-K is offline
Send a message via AIM to V-K
Re: Re: Car Won't Start!
I second this, I had the same issue with mine. New rotor/distributer cap/and ignition coil fixed me up*
Old 08-07-2004, 04:19 PM
How much does an ignition coil run??
\m/ (-.-) \m/
Old 08-07-2004, 05:08 PM
Hybrid1990crx's Avatar
ONE million dollars!
Old 08-07-2004, 09:44 PM
91hbman 91hbman is offline
Send a message via Yahoo to 91hbman
i had the same problem, intermitent starting, thought it was the fuel pump, it wasnt making the priming sound, but actually it ended being the ignition switch. easy and relatively cheep fix, at least compared to a fuel pump.
Thanks for any of the help that anybody has offered. I try to do the same. And remember "It takes all kinds to make the world go round."
Old 08-14-2004, 05:47 PM
fiercecivic's Avatar
fiercecivic fiercecivic is offline
Send a message via AIM to fiercecivic Send a message via MSN to fiercecivic
usually its ur main relay, the moisture gets into the solder points on the cicut board and dosnt make a complete connection, therefore not allowing the car to start. This is a fairly easy and cheap fix. The main relay is located under ur change box on the left hand side of the car. beside the fuse panel. one bolt and a plug and its off
Old 08-14-2004, 06:30 PM
vladlos's Avatar
vladlos vladlos is offline
Send a message via AIM to vladlos
yea, i had the same problem before....and everything totally sucked...i changed my ignition coil, distributor cap, and spark plugs and everything ran smooth like gravy
Old 08-14-2004, 07:25 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
dizzzy cap- $15
Rotor- $4
Plugs- eh... anywere from 50 cents to $15 each
main relay- $80
I'd start with plugs/cap/rotor
Old 08-14-2004, 08:34 PM
1990civicdxhb's Avatar
1990civicdxhb 1990civicdxhb is offline
you could take a look at your altenator/belt or the fuel system
Old 08-14-2004, 09:40 PM
90civicracer's Avatar
90civicracer 90civicracer is offline
Send a message via AIM to 90civicracer
Do you have gas in your car
***90 Civic EX 4 Door***
Ace$nyper: yea it did woo woo 4500 posts i should be ashamed *kills self*
90civicracer: haha you killed yourself you got
Ace$nyper: OMFG LOL that might be the funniest thing you EVER posted
bwhahahaha
