| Car Audio Do you live in your car? Then you need to be able to listen to some high-quality music. |
Newby : choosing right comb speak and amp
I'm new in car audio, i have some question & need some advise.
1. i have front speaker rated w50rms and rear speaker w60rms each. I planning to buy Kenwood 4 chan amp (62rms x 4 @ 4 ohm). The question is could my speaker handle the power when i blasting at full volume or should i choose the same rms power or lower then the front speaker is. 2. I also planning to buy single 12" sub rated 200rms and Kenwood 1000w mono amp rated 200rms. Is this suit for the sub or i need more power. can it handle at full volume too? Need some info and comment too. thanx |
Re: Newby : choosing right comb speak and amp
![]() that kenwood amp would work fine, but it sucks, get one of those package deals aat ED, if you can swing it, a set of components, and a 70x2 amp to power them, i'm sure that you will be much happier...
the aquabats are seriously the best band in the world |
that company needs a better website
Re: Re: Newby : choosing right comb speak and amp
Re: Re: Re: Newby : choosing right comb speak and amp
-------------------------------------------------------------------------------- Originally Posted by aznxthuggie u deserve a COOKIE!! -------------------------------------------------------------------------------- psht, tell me about it!!! sorry i'm not very sure, what do you mean by u deserve a cookie? My english is bad |
I just wasn't awake yet... but yes good company. I like the website personally
www.cloudcity.deviantart.com |
cookie=reward
Now I understand. I've seen edesign and it's look great but it quite expensive for me. I don't have enough budget for it but thanx. I will look for another budget amp there is good out there.
Here another question if you don't mind. I having trouble to figure up how to wiring a two amp. The first amp is for a speaker and second is for sub. here it goes, If I connect the output(front and rear) from HU using RCA cable to my my first amp. what about the sub amp. Please give me a correct way to install it. Thanx in advance to all that help |
Re: Re: Re: Re: Newby : choosing right comb speak and amp
is that the scenario?
Re: Re: Re: Re: Re: Newby : choosing right comb speak and amp
does your amp have rca pre-amp outputs? if yes, then just use those to feed signal to your second amp
THE DARKNESS!!! an African Soup Bone Production... |
You will need a headunit that has outputs for Front, Rear, and Subwoofer...unless of course the idea Navy I.C. has is an ok way to do it. Isnt the signal in the subwoofer output different from the other one? I would think it is cause of the lower frequency.
