Old 07-28-2004, 09:56 PM
JeSsToNeS JeSsToNeS is offline
Send a message via AIM to JeSsToNeS Send a message via MSN to JeSsToNeS
Question wireing neons
Im currently putting Neons under my car and I was wondering if any of you guys here could help me out, I have a 93 z24. I have one neon in the front by the air dam (behind the bottom lip of the body kit) but its one of those neons where you have to plug into the cigerette outlet. I wanna get some toggle switches installed for the ones outside and inside of the car. If any of you guys here could help me out or point me to a website on how to do that I would appreciate it greatly. Oh yeah what kind of supplys would I all need to do that job?
Old 07-29-2004, 10:06 AM
SlamedCAVY SlamedCAVY is offline
Send a message via AIM to SlamedCAVY Send a message via Yahoo to SlamedCAVY
Re: wireing neons
Hey whats up bud, your best best to wire everything up with the switches is to either use the big high amp switches with I think are ugly or use high amp relays. Also make sure you got really good grounds where ever you need them...scrap the paint away from the area and get it on there really tight. Your best bet is the soder all the connections as well. and under the car make sure you try and get everything water tight. and just alittle advie to save you some imbarresment...when you mount the underbodys, make sure you cant see the bulbs unless you stick your head under the car. Hope everything goes well
Old 07-29-2004, 08:54 PM
02cavy 02cavy is offline
Send a message via AIM to 02cavy
Re: wireing neons
the quick and easy way (though granted is not as professional) is to just cut the cig. lighter plug off, run the pos to the togle, neg to a ground, and a wire from the battery (or any constant +) to the togle. that'll do the job. and to echo the previous advice, PLEASE make sure your underbody bulbs aren't visible. nothing says "i don't know what i'm doing" like a visible underbody kit.
Old 07-30-2004, 03:19 PM
Three_Fingers Three_Fingers is offline
Re: wireing neons
Heh. Make sure you put fuses inline for those. Nothing says "I'm an idiot" like burning your car to the ground cause ya didn't bother to fuse your wiring and something shorted out.
