Old 07-28-2004, 09:10 PM
Ismyee Ismyee is offline
Blown Head Gasket?
Bluish white smoke is blowing out my 91 Civic exhaust. My Radiator coolant is constantly getting low and my car is overheating. I've been told that my head gasket may be blown. I was also told that if the head gasket is blown than the header might be warped. Would it be a good idea to just put a new gasket on and see what happens or buy a new header and gasket at the same time just to be safe.
Old 07-28-2004, 09:23 PM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
Re: Blown Head Gasket?
..header may be warped? I think you may have miss understood.. I think they probably said head....and really, I think this is only true if you really overheated your car b/c of the blown gasket... somebody correct me if I'm wrong..
SOLD!
Old 07-28-2004, 09:33 PM
civic_boy91's Avatar
civic_boy91 civic_boy91 is offline
Send a message via AIM to civic_boy91 Send a message via Yahoo to civic_boy91
yeah i think they said head...and you didnt over heat your car till it stalled or ran like compleat shit did you..if not just get a new gasket...make sure its the head gasket and the rad ..make sure its not leaking somewhere ... cars with high miles smoke blewish white ...that is worn rings. its normal to smoke a little (and get worse as revs go up). check some hoses and look for puddles under the car...
_________________________________http://VelocityFactor.com________________________________
1990 si hatch
b20b si tranny
megan race header 2.5 custom exhaust
50 shot
integra da rear disk (w/ 4040 valve)
powerslot rotors and barded lines all around
1994 Dx hatch
stock
Old 07-29-2004, 12:41 AM
RedRacerCivic's Avatar
RedRacerCivic RedRacerCivic is offline
Send a message via AIM to RedRacerCivic
blown headgasket....you might want to resurface the head before new head gasket install.
-1991 Civic Si (Sold)
-1990 Accord EX(Sold)
-2000 Civic Hatch
-1998 Lexus SC300
Click here to see my Shoe!
Old 07-29-2004, 11:01 AM
dssmax's Avatar
dssmax dssmax is offline
If you put cold water in you Radiator after your car over heated and your engine was not running, that will cause the head to warp. Among other things..
MAX
Your Signature
