Old 07-28-2004, 08:55 PM
MasterBraetec's Avatar
MasterBraetec MasterBraetec is offline
Send a message via AIM to MasterBraetec
Coil Over kit questions
Has anyone here ever used a coil over kit, How hard is it to install? Does it make the ride tighter or loose and what other effects, if any can it have?
Never Underestimate The Power Of STUPID People In Large Groups !
Old 07-30-2004, 12:26 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Coil Over kit questions
Man, is that a loaded question....
I use one. It wasnt too hard to install, took an afternoon.
For the rest of your question, it depends entirely on what your car weighs, FWD or AWD, how you intend to drive it (street, drag, autox/roadrace, etc), shock valving and settings, spring rates, how the spring rates relate to shock valving, and ride height of the car.
If you want to fill in some of these blanks I can make a shock and spring rate recomendation, but this is more of an art than a science and experience is the best teacher
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 07-31-2004, 10:11 AM
dsmodder dsmodder is offline
Send a message via AIM to dsmodder
coil over is a lot better than springs and shocks. and usually for our dsms the coil over kits dont lower the car too much so you dont need to worry about alignment kits or eatin up tires.
Old 07-31-2004, 10:21 AM
AF - Advisor
My coil over kit will put the car on the ground if I want to... OR I can go higher than stock. Thats the whole point, these things are adjustable.
Kevin Jewer
Old 07-31-2004, 02:21 PM
i dont have one yet but im gettin the tein street damper setup for 1k. 16 way damp adjustable and ride height adjustable. im only planning on lowering mine about 1.5 inch. cuz my 18 inch rs5
Old 07-31-2004, 02:30 PM
gsxracer what coilovers do you have and how do you like them? also, whats the lowest you have gone with the coilovers(to the point that you could tolerate for street driving) and what size rims/tires did you use?
Old 07-31-2004, 04:27 PM
AF - Advisor
I use the Ground Control kit with standard diameter race Eibach springs, 450 pounds front, 325 rear, on Tokico Illumina asjustable shocks. I also went with the GC billet upper mounts to gain another inch of travel for another 200. I keep it pretty low, some of the pictures on my site must show it. Wheels tires are 17x7, 215/50/17. If I did it all over again I would go with Konis, the tocikos dont last very long with my spring rates. OTherwise I'm very happy with it. HAndles way better than stock, and pulls down to 1.5s for short times on those 17" street tires. Can't complain
Kevin Jewer
