Old 07-28-2004, 08:44 PM
farmer11 farmer11 is offline
Question Wireing for hitch
Is there an easy place to hook up the wires for lights and signals? I looked in the compartment where the jack is but couldn't decide if that would work.
Thanks
Old 07-28-2004, 11:38 PM
caravanbob caravanbob is offline
I'm not sure what years yours is, but...
For both my '98 and my '01, I bought pre-made plug in harnesses. For both of them, I had to remove one tailight assembly (as though you were changing a bulb) and then slice the grommet where the wiring came out from the body. The trailer harness was fished into the tailight area from inside the van (where the jack goes), and through the grommet. The trailer connector is a "t" type of arrangement. The factory connector was unplugged from the stop/turn/tail light, the trailer harness plugged in in its place, and the factory harness plugged into the remaining pigtail.
Old 08-18-2004, 11:05 PM
JeffL. JeffL. is offline
Re: Wireing for hitch
Caravanbob,
Where did you get the T-connector for the trailer harness? Was it just an aftermarket or was it from Dodge?
Also, do you have a Class II or III hitch? I'm trying to find one that is a lower profile, so it doesn't stand out like a sore thumb. Although, I'll never use it for towing over 500 lbs, I'd like to go with Class III. This way I can use my cargo carrier and different hitch configurations that goes on my truck as well.
I know I'm full of questions, but I hope you can help.
Thanks,
Jeff
Thanks,
Jeff
Old 08-22-2004, 08:02 PM
Jeff,
For the '98 I had, I got the harness a Pep Boys. For my '01, I ordered it with my hitch, but I believe that Pep Boys has them (or can order them for you).
I use a class 2 (1 1/4") hitch. The only thing you can see of it is the square receiver.
Bob
Old 08-22-2004, 10:21 PM
I appreciate the feedback. I'll definietly look at PepBoys.
thanks again,
Jeff
Old 08-23-2004, 11:00 AM
Poppa Bill Poppa Bill is offline
Hello everybody I just got a 02 Dodge cavaran and installed a class 2 Reese hitch. It fit beautiful the bolts are there and you don't even see it when ball insert is removed.
One problem There is two wires on each side hidden in a spot you will see a rubber plug pull it out and upon checking for power i got nothing. I didn't want to pay the high price for the harness ,I to looked at wiring in jack compartment. But there is no slack.
I am going to inquire today. ------ Later Bill------ compared to $80.00 for harnesss
Old 08-25-2004, 01:41 PM
Have you looked around on-line for prices for the wiring harness? $80 is way out of range.
Here's one for $51: http://hitches4less.com/20dodcargran.html
Better yet, heres one for under $30:
http://www.etrailer.com/Merchant2/me...egory_Code=VWH
-Bob
