Old 07-28-2004, 06:43 PM
dmack00 dmack00 is offline
Red face 88 grand am cam timing gear replacement
i'm trying to replace just the cam gear(teeth missing) but i'd rather not have to remove engine and cam. is there a special puller or tool to make the job easier for me? any help or tips would be appreciated. auto book says "normaly engine and cam must be removed" which leads me to believe not absolutely
Old 07-28-2004, 06:53 PM
catback23 catback23 is offline
Re: 88 grand am cam timing gear replacement
Depends on how much room you have. If you can get a gear puller in there then you won't need the engine out.
Old 07-28-2004, 07:51 PM
thanx for the reply catback. not much room, maybe 2-3 inches. pullers i looked at do not look good to go. centre bolt on pullers look to be too long
Old 08-31-2004, 09:06 PM
mrrob mrrob is offline
How Did You Make Out?
How Did you make out, I've found that you can usually split the gear by drilling each side, the when you get it off, sometimes the shaft for the gear is threaded other times you'll have to make a thread, either by using a tap or running a bolt through.
Good Luck!
Old 09-01-2004, 12:20 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
if it's a 2.5, the cam gear cannot be removed with the engine in the car. The gear is pressed on and the puller required to remove it will not fit in the engine compartment.
Old 09-01-2004, 08:11 PM
Re- Timing Gear
I know for a fact that the gear can be split(thus not having to pull the motor) I was given the information from a friend who is a GM master Tech, GM has had a noise problem at start up with these gears, This is a GM dealer fix. Also A Mr.Rob Fix I have Done 9 and have never had to pull the motor.
You do not have to pull the Motor..
Mr.Rob
Lic Mech Auto/Truck/Diesel/Propane/ASE Master Tech.....
