Old 07-28-2004, 06:47 PM
Mercad Mercad is offline
Piston Upgrades
How do I go about upgrading the pistons in my 420A since most aftermarket pistons are larger than the stock bore width? Who does this and how much will it cost?
...or...
Are there aftermarket pistons out there that will fit into a 420A w/out any mods and yet be strong enough for a 10+psi turbo kit?
Old 07-28-2004, 07:22 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: Piston Upgrades
Whenever you do a rebuild, you bore and hone the cylinders, so if it was your first rebuild you would probably bore .020 over, and get .020 over pistons.
Stock motor can handle low boost depending on the turbo. Please learn what you're talking about before you ask questions about things you will never do. 10 psi means absolutely nothing, it depends on the turbo.
Turbo your RS the same way everyone else does, by learning exactly how from the guides already out there. One is stickied on this forum, 2gnt.com is also a good site.
Old 07-29-2004, 12:30 AM
Re: Piston Upgrades
and how would I go about getting the motor bored and honed, and how much would it cost?
Old 07-29-2004, 07:59 PM
JoeWagon's Avatar
Banned
Re: Piston Upgrades
If you don't know, you'll be bringing the car to a shop. They can tell you exactly what you'll want, because I don't know N/T's.
