Go Back   Automotive Forums Car Chat > Fabrication & Tools > Metal Shaping and Welding
Metal Shaping and Welding Discuss metal shaping and welding techniques. Share your projects or tips and tricks.
Old 07-28-2004, 02:43 PM
sleepyPrix sleepyPrix is offline
turbo fabrication
Has anyone fabricated a turbo system for their car?
Old 07-28-2004, 02:49 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Re: turbo fabrication
I have seen turbo's/superchargers fabricated, but it sure isnt easy. Most of the parts would need to be milled on a CNC mill. We are talking very fine engineering, especially for the spool.
I have seen a supercharger also made for a 1/10 RC car.
-Mike
Old 07-28-2004, 03:18 PM
Cbass's Avatar
Cbass Cbass is offline
Send a message via ICQ to Cbass Send a message via AIM to Cbass Send a message via MSN to Cbass Send a message via Yahoo to Cbass
My brother and I fabricated a turbo manifold for his carbureted 22R RA40 Celica, years ago. Basically we took pipe fittings, 30s, 45s and 90 degree elbows and made the whole thing out of sched 40 1.5" pipe. All of the fitting was done with eyeballing and angle grinders.
Had the thing welded up by a local shop, cost about $100 to have welded, and the fittings were free since my uncle runs a pipefitting shop. We plumbed it through the carb with a blowthrough box, basically just a sealed box that fit around the stock carb. A rising rate FPR was used as well, and surprisingly there wasn't any detonation until about 14psi or so.
The turbocharger was a junkyard T3 from a Thunderbird 2.3 turbo, it was a 60 trim T3 IIRC, and it seemed to suit the 22R pretty well, although there was some lag to be sure. A 3" downpipe was used, which dumped just behind the front wheels. It was ghetto fabulous.
Unfortunately, it seems that the stock pistons were never really made to handle that kind of heat, and after a highway run, one of the ring lands gave up and that was it for the motor... Live and learn, it was a $500 car.
Connor - Porsche Nazi since 2001, VW defiler since 2004
This here's a Fabrication forum!
My lugnut requires more torque than your LS1 makes.
Old 07-28-2004, 07:01 PM
Integra06's Avatar
Integra06 Integra06 is offline
^Pretty cool and fun experiment.
I agree though, it would be very difficult, time consuming, and budget consuming to make a one off for your self because of the precision machining required.
Come see AF's new Fabrication board.Click here!
Old 07-30-2004, 01:23 PM
SaabJohan SaabJohan is offline
I assume that the threadstarter mean a turbosystem, not to fabricate the actual turbocharger. To fabricate a turbocharger is extremly difficult and costly.
Old 07-30-2004, 09:02 PM
yea, i meant a system, not the actual turbocharger. Thanks for all your input guys.
Old 07-31-2004, 12:29 AM
Integra06's Avatar
That shouldn't be too hard if you have some sort of an idea of what you're doing. I myself won't be doing any fabricating for a little while since I cut my hand pretty bad today. The wound is about 2 cm long, maybe a little longer, and 4 mm deep. It took 5 stitches to close up, it hit a vessel, and lost quite a bit of blood. I'll have pictures tomorrow. Funny thing is, I didn't feel a thing when I cut it, when they sewed it up, or about an hour ago; but now it hurts like hell. Happened about noon, but the emergency room trip was only an hour and a half, which is pretty damn fast around here.
Old 07-31-2004, 09:54 AM
Cbass's Avatar
Sorry to hear it man, that sucks... Hope you didn't do any permanent damage, that's been scaring me about my wrist, what if doesn't heal right, etc...
Where do you live that it takes so long to get to the ER?
Old 07-31-2004, 12:07 PM
mike@af's Avatar
Um, still fabricating a turbo system isnt all that easy. You cant just have tubes cut to lengths to fit. Engineering everything perfectly and caluclating everything perfectly prevents detonation which can ruin an engine. Detonation is bad...
-Mike
Old 07-31-2004, 09:39 PM
Integra06's Avatar
I meant the wait in the ER, sorry about that. The time to get there is only 10 minutes, and the entire trip and visit was the 2 hours. BTW, I live on the outer part of Houston.
Here's some pics for those without weak stomachs, although it's not bad at all. I lost almost a pint of blood into my trashcan and the bathroom sink. So, heres the pics below.
Good thing I'm left-handed.
Old 08-01-2004, 09:46 AM
mike@af's Avatar
What the hell did you do? I have probably needed to get stitches about 20 times but never have.
-Mike
Old 08-01-2004, 05:13 PM
Integra06's Avatar
Re: Re: turbo fabrication
I had a pretty sharp knife that I used for making wood carvings that slipped, went through two layers of leather, and made the cut. The guy who sharpened it for me when I bought it told me it would be as sharp as a scalpel. Oh well, it's not my first time with stitches, hell, I've put a knife through my leg once and busted my head open several times when I was young.
Old 08-02-2004, 05:22 AM
Cbass's Avatar
By far the trickiest part is the manifold itself, in many cases there just isn't enough room to make a log type, so you have to make a merging header in the space you have to work with. Also, you really have to know what you're doing to weld 1/8" tube to 1/2" plate for the flanges, you have to pause alot longer on the heavy side to get any sort of good penetration.
Most of teh stuff like the intake plumbing, downpipe, oil and coolant lines etc are pretty easy by comparison. If you have access to a mandrel bender and the right dies, it makes things a lot easier. If not, you have to buy prebent pieces and work around what you can get, which means you usually end up making a mitre or two to get things to fit just right.
That looks like a pretty nasty cut Integra06, I hope you heal as fast as I do. My doctors is just astounded that the bone in my wrist had set and fused after one week, he says it usually takes at least two weeks. On top of that I'm now carrying 20-60lb tool boxes around and wrenching on my car! I see your sig and avatar are pretty arc intensive, are you a welder?
Old 08-02-2004, 07:32 PM
Integra06's Avatar
Re: Re: Re: turbo fabrication
It should heal pretty fast, I hope the same for you too. I'm only 16, but I work in a chopper shop as a welder/machinist, so it hasn't really slowed me down there. I do more drafting and machining than anything, so that also helps me keep working. For the past year, I've been in a welding and machining class at school. My dad works at the Budweiser brewery, so when I'm a senior next year, I'll be going to school every other day and doing my machinist apprenticeship with him the other days. After I graduate, I'm thinking about going into the Navy if they'll let me finish the apprenticeship. In the end, I still want to go to college for engineering. Probably 90% of my family right now are teachers so I kinda wanna do something different.
Old 08-03-2004, 01:13 PM
mike@af's Avatar
Usually the penetration wont matter is much when your just doing a fillet weld (and its not for structural use), but still, welding two different thicknesses is the biggest pain in the ass. Especially welding .063 to .25, thats tricky ass hell.
-Mike
