Old 07-28-2004, 11:36 AM
blam22004 blam22004 is offline
Send a message via AIM to blam22004 Send a message via Yahoo to blam22004
Question 4.3 Blazer motor
I have a 1995 Blazer with a 4.3 Vortec motor that has a slight crack in the cast block and I was wondering if a 4.3 block from a older Blazer would be the same?
Old 07-28-2004, 12:07 PM
quaddriver quaddriver is offline
Send a message via AIM to quaddriver Send a message via MSN to quaddriver Send a message via Yahoo to quaddriver
as long as you get one with the balance shaft you will be ok (the CORRECT balance shaft - there were 2 versions)
Old 07-29-2004, 05:38 PM
tom3 tom3 is offline
Re: 4.3 Blazer motor
Know a guy with a big semi. Cracked block in the big diesel, antifreeze leaking. Ground it down and covered it with JB Weld, fixed it for a couple years of hard use. Amazing stuff, I use it quite a bit. If the engine is fine otherwise, worth a try if you can get to the crack and get it clean and dry.
