Old 07-28-2004, 10:28 AM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
Electrical problem
my 89 5.0 won't start... in fact it won't even crank. everything else in the car works. it cranks if i bridge the starter relay with a screwdriver. i figure there must be something wrong with the starting circuit. also, there's a small red light right next to the dimmer switch that blinks on and off 3 times every 2 seconds or so. i'm told this isn't stock... could it be some sort of aftermarket igition killswitch that i don't know about?
today i'm going to try and fire it up with the igition on and the relay/screwdriver trick... maybe that'll cancel it out. i doubt it, but who knows. i wanna at least hear it run for a minute... my poor car... i have to at least turn it around so my brake job today goes a little easier.
any ideas as to how to bypass a killswitch or jsut diagnose the starting circuit are appreciated... thanks guys.
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
Old 07-28-2004, 03:54 PM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: Electrical problem
That blinking light is more then likely an alarm system someone had installed. I had a problem once when the replay for my alarm went bad and my car would not start or even turn over. It was as simple as replacing the relay for the alarm. Mine was located in the steering colum. you may have to bring it to an stereo/alarm shop and see if they can disable the alarm system.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 07-28-2004, 04:13 PM
actually, a few hours after i posted this i found the problem... there's a killswitch installed just under the dash, to the right of the fusebox. it was a simple matter of turning it back on and now it starts flawlessly. i spent the last few hours installing my new front brakes and wheel bearings, and it's made a huge difference in my drivability. now if only i can find a timing light.........
thanks anyway hiflo
-Andy
