Old 07-28-2004, 11:16 AM
aces1980 aces1980 is offline
crank pulley?
will the crank pulley from a a6 fit a y7?
Old 07-28-2004, 03:31 PM
91civicDXdude's Avatar
Re: crank pulley?
yes. but on using the a6 alternator, as the a6 and y7 have different number of ribs on their alternator belt.
Old 07-28-2004, 04:01 PM
Re: crank pulley?
thank you bery much. since i am going to remove the crank when i nstall the a6 one i have to redo timing right?
Old 07-28-2004, 08:49 PM
Re: crank pulley?
yessir... have you asked this question before? i get a weird dejavu feeling about this thread like i've already had this exact same thread before.
<insert twighlight zone music here>
Old 07-28-2004, 08:50 PM
Re: crank pulley?
wait a sec... if you have a Y7 block and it already has the crank pulley, you can use it as it is.. the Y7 has more ribs on the alternator belt, as long as you use an OBD0 alternator, you can just use the skinnier d16a6 alternator belt and dont use one rib of the pulley.. thats what i did on my Y7/Z6 mini
Old 07-28-2004, 10:51 PM
Re: crank pulley?
right but the a6 alternator belt is too short and does not line up right. I wonder if a z6 one will work? which one did you use
Old 07-29-2004, 10:01 AM
Re: crank pulley?
oh i remember now.. I used a Y7 or Z6 belt (i found it laying in a pile of used belts :P ) and i cut a rib off the belt itself with a utility knife.
hey it works.. no problems :O
Old 07-29-2004, 12:56 PM
Re: crank pulley?
and what alternator are you using?
Old 07-29-2004, 06:16 PM
Re: crank pulley?
OBD0 skinny pulley alternator. i still have the y7 pulley on my block.
