Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 07-28-2004, 08:49 AM
oakleyp2 oakleyp2 is offline
Angry Takes about 10 tries before it starts #$%
I have a 1985 300ZX. the car runs pretty good after you get it started but it takes about 10 - 12 tries before it starts. Almost like it's loosing it's fuel prime, like it has to pump back up. i can hear the fuel pump running but it never shuts off.
would the fuel pump or fuel pressure regulator cause this problem??
Old 07-28-2004, 12:38 PM
prodigy99 prodigy99 is offline
Re: Takes about 10 tries before it starts #$%
try putting the key in the ignition, click it all the way but stop prior to cranking...leave it a few seconds, so the fuel pump pressurizes the system and give it a try.
you might want to check all your plugs and connectors, they might not all be firing, since the car only runs pretty good, if it vibrates, then it means some of your plugs arre missfiring.
Old 07-28-2004, 02:19 PM
longlivetheZ's Avatar
longlivetheZ longlivetheZ is offline
Send a message via AIM to longlivetheZ Send a message via MSN to longlivetheZ
Sounds like a fuel system prob to me. Do what prodigy said and if that doesn't work, check the fuel pump, fuel filter, fuel lines, pres. reg., etc.
Who cares what's in your wallet...what's in your garage?
VG30ET in process of rebuild on left and my 88 300ZX NA, 2 Seater, 5-Speed...my 3rd Z31
Hope you can see the tiny pic...AF reduced the size limit!
Beer is living proof that God loves us and wants us to be happy. --Benjamin Franklin
Old 07-28-2004, 02:28 PM
basic tune up done when i got the car, plugs and wires ect..... i have tried leaving the ing. switch on for a minute or so and see if that helps but it dont.
I guess i will the fuel system out. thanks for the help!
Old 08-02-2004, 07:04 AM
Clamp the fuel return line and she runs like a champ.
Old 08-03-2004, 05:40 PM
Hodo Hodo is offline
Make sure you have the 3 fundamentles of car starting,
1- Fuel
2- Air
3- Fire/Spark
Check to see if your fuel pressure is in the spec. zone.
Cause it sounds to me like you have a weak pump thats not getting the system to its proper pressure levels.
But I am just a lowly Volvo tech.
