Old 07-28-2004, 02:43 AM
anthony90si anthony90si is offline
1.8 clearance
i was told that i would have to get a new hood so i could fit a b18. is that true. is there a way around it.
Old 07-28-2004, 01:00 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: 1.8 clearance
Saw three this weekend at Texas Heat Wave that had factory hoods running b18's
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
Re: 1.8 clearance
see the hood on my car? stock...
geuss what's under the hood.
2002 Acura TL Type S
1991 Honda Crx Si
Old 07-28-2004, 01:21 PM
QuikShifter's Avatar
QuikShifter QuikShifter is offline
Re: 1.8 clearance
I think it also depends on the kind of mounts you use. alot of companies have corrected this issue, so you can use your factory hood.
Old 07-28-2004, 02:10 PM
pauls81sc pauls81sc is offline
Re: 1.8 clearance
I think QuikShifter is right. Check out the hasport website, in the mounts section it'll give you the details.
1989 CRX Si (commuter)
1981 Porsche 911 SC (weekend TERROR!!!)
Old 07-28-2004, 08:09 PM
shaddr3 shaddr3 is offline
Send a message via AIM to shaddr3
Re: 1.8 clearance
only motors i've seen with modified hoods in a rex is a ZC and a K20
89 CRX Si
B16 | BW Body kit | 17" 8 Spoke | Airbagged
Old 08-03-2004, 09:40 AM
4thgensvk 4thgensvk is offline
Send a message via AIM to 4thgensvk
Re: 1.8 clearance
if it is ls vtec the hood may not fit my friend had that problem on his crx and it came up pne day and smashed his whole windshield
Old 08-03-2004, 09:50 AM
johnnym's Avatar
johnnym johnnym is offline
B18A fits with the stock hood and HCP mounts....
Old 08-03-2004, 01:11 PM
Hybrid1990crx's Avatar
Re: 1.8 clearance
But I believe that if you have mounts that let the hood close without touching the valve cover at all means that your motor is sitting really low. Which means you gotta be carefull of shit hitting your oil pan.
Old 08-03-2004, 02:59 PM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
Re: 1.8 clearance
also you can just cut the skelaton not what i'd reccomend but i've seen it done before but should slide in fine. Be cool get a C/F hood just incase =)
