Old 07-28-2004, 02:23 AM
Faze2183 Faze2183 is offline
Send a message via AIM to Faze2183 Send a message via Yahoo to Faze2183
my poor baby is runnin so bad
ok the other night my truck was running like crap, its back firing, its got no power, its just runnin so bad its not even funny on how bad its running....
i took it to a shop they thought it was the fuel pump but its readin all the right psi and etc....and voltage and etc....
then they scaned it and they thought it was the mass flow but i luckly had an extra layin around so they tryed that, still nothing
any ideas?
its a 1996 chevy k1500 4x4 with 5.7, 165k miles, uhhh, tune up was done 150k hmmmm if yall need anymore info let me knw
Old 07-28-2004, 02:31 AM
Re: my poor baby is runnin so bad
could their be a timin issue? or???? theres all kinds of codes bouncin around and so.....ya
Old 07-28-2004, 02:33 AM
ill try to get what info i can and etc....
Old 07-28-2004, 02:43 AM
manwiththeplan manwiththeplan is offline
Send a message via AIM to manwiththeplan Send a message via Yahoo to manwiththeplan
i had that same exact problem in my S10. Initailly we thought it was the cat. and it was indeed cloged like a mofo. after repalcing that it ran fine for about 3 weeks and then shat again. it turned out to be an issue with the ABS. No shit i saw the flow chart and the diagnostic. The ABS caused a missfire. Is your ABS light on. You may want to look into that.
Old 07-28-2004, 07:45 AM
Thunderbolt Thunderbolt is offline
I assume the SES light is on correct ?? Do you know what any of the codes are ??
Old 07-28-2004, 11:58 PM
i found out that my timing was off by -17 degrees....
im guessin thats bad?
with it bein off what kinda things would i excecpt? other than what i said from be4 and etc????
Old 07-29-2004, 01:54 AM
TweakedGM TweakedGM is offline
your timing should be at 0 degress plus or minus 2 degrees is ok. BUT YOU KNEW THAT FROM THE OTHER THREAD SOME ONE TOLD YOU ABOUT IT.
Old 08-01-2004, 12:22 PM
ya, the timing has be off for some time at least a year i think, but now it runs good and etc....all i gotta say is thanks to aamco transmission for making the job get done right
Old 08-01-2004, 06:20 PM
Jeremy-WI Jeremy-WI is offline
17 degrees off? Do you have a bad distributor gear or what? That should have set a P1345
Old 08-02-2004, 12:20 AM
yes sir it sure did
