Old 07-27-2004, 09:22 PM
dln dln is offline
S-10 4x4 Blazer Lower Ball joints
How does a person remove the lower ball joint without removing the top?
The bottom A arm seems to be on a torsion bar type suspension. I can't get enough clearance between lower A arm and spindle to remove the joint.
Old 07-28-2004, 06:24 AM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
Re: S-10 4x4 Blazer Lower Ball joints
You'll have to remove the stabilizer/torsion bar from the bottom plate, and probably remove the clamp that holds the bar to the frame closest to the joint you're working on. You might also try removing the steering tie-rod to give you some flexibility moving the assembly around.
Good luck,
Mike
Old 07-28-2004, 11:01 AM
quaddriver quaddriver is offline
Send a message via AIM to quaddriver Send a message via MSN to quaddriver Send a message via Yahoo to quaddriver
put a jack under the lower arm, knock off the tie rod, pickle the lower joint, then simply push the upper control arm up and lower the jack until the t-bar hits the limit of its travel
