Old 07-27-2004, 07:26 PM
302nsty 302nsty is offline
gt40 heads or are they stock?
i have bought a used 5.0 engine to build for my currently running95 5.0 . i dont know if anything the guy said about this motor was true .. the question u have now is ... i pulled the heads off . how do i know if they are gt40s like he said ? he said the motor came out of a 95 cobra ... they have the letter s stamped in the corner and the number 19 stamped on the opposite corner i think... if they are gt 40 or cobra heads i plan on replacing my stock heads with these .. please help. someone ..
Old 07-28-2004, 01:12 AM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
Either on the end of the heads or around the valves(i forget), there should be three slash marks next to each other. (l l l)
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 07-28-2004, 04:23 PM
Re: gt40 heads or are they stock?
ok well i dont see any slash marks the only markings on the head are the letter S , the number 19 . and E6SE is stamped on the underside of the head that faces the tops of the pistons... so what kind of heads are these ?
Old 07-28-2004, 06:09 PM
SVTcobra306's Avatar
SVTcobra306 SVTcobra306 is offline
Look in the top under where the valve cover would be, GT-40s will say GT, GT-40p's will say GTP.
My Ford engine parts interchange book ends in the 70's with no mention of these. The heads you have stock on your GT are E7TE truck heads, the casting number leads me to believe they are either 83-84 heads or 85-86 heads, both of which were pretty much junk... Hope I'm wrong, but if I'm right, sorry for ya.
1994 SVT Cobra. 306, Ported GT-40X's, Crane 2031, NX Wet Kit (100 shot for now),TKO 500, TwEECer R/T, and all the bolt-ons.....
http://www.cardomain.com/id/mccobra94
1995 F-150 SC/4X4 351W/E4OD, K&N, Custom Exhaust w/Flowmaster.
Freedom Isn't Free.
