Old 07-27-2004, 06:46 PM
f150 f150 is offline
88 F150 302 hard to start when cold?
The engine starts and runs good when it is warmed up, but after it sits for 30 minutes or overnight, it takes it a minute or so and a few starts before it will run. It is like the engine's fuel injectors are not giving it enough fuel to run. Is this an ecu problem or some other sensor that can be changed out fairly easily. and what part or parts do I ask for at the parts counter?
Any help is appreciated. Thanks
Old 07-28-2004, 09:25 AM
landyacht's Avatar
landyacht landyacht is offline
It's just an old truck that doesn't like the cold. Something that should help is tapping the gas pedal before you turn the key over, and feed it a little gas while cranking it.
My old car requires this to start in cold weather, same issue if i don't do this with the car.
Mine's an '82 Pontiac Parisienne 4-door sedan!!
- 305 cu inch (5.0L) small block V8 w/ 3spd auto
- 4 barrel carb w/ single exhaust
- No catalytic converter, no posi-trac
NEVER LOSE FAITH IN THE BOAT!!
Old 07-28-2004, 09:26 AM
landyacht's Avatar
Re: 88 F150 302 hard to start when cold?
This isn't just for cold weather by the way, also do this if the engine is cold, i have to this when my car sits overnight.
Old 07-28-2004, 04:06 PM
Tapping the gas pedal works on carburetors but not on fuel injection, carbs have accelartor pumps fuel injection doesn't.
Old 07-28-2004, 07:20 PM
Car Pal Car Pal is offline
the fuel pump has a mechanical float and that could be stuck. gas leaks back down into the tank.
a fuel pressure gauge would tell if there is a leak down.
Old 07-29-2004, 07:02 PM
97chevyman's Avatar
97chevyman 97chevyman is offline
check the fuel pressure. Could be low, is your gas milage down also? Try a new pump and filter is your fuel pressure is low. Autozone and most places will lend you a fuel pressure gauge. hook it up and turn on the key and see if it jumps right up to where is should be, if it doesn't, first try a new regulator and filter then pump if it still does it. if your fuel pressure comes right up and is fine, do a compression test, if you have low compression, the minute of cranking when cold would build up enough fuel in the cylenders to start, and when its warm the rings are already expanded so you have good compression.
2000 ford F-250 4x4 CC auto
1978 F150 4x4, 6 inch lift painted john deere green
Old 07-30-2004, 11:58 AM
landyacht's Avatar
That is the case in most instances, but i've found i had to do this with 1 year old Explorers and such when they'd been sitting overnight to get them to go.
They weren't low on fuel when i had to do this....you're right, but i've found it to work...just my experience.
