Go Back   Automotive Forums Car Chat > Honda > Integra
Old 07-27-2004, 04:47 PM
Sic91Integra's Avatar
Sic91Integra Sic91Integra is offline
Coil Overs Vs Springs
what would be better for a 1.5 inch drop and can u give me pros and cons of coil overs or springs thanks
Old 07-27-2004, 05:18 PM
Mannyb18b's Avatar
Mannyb18b Mannyb18b is offline
Send a message via AIM to Mannyb18b Send a message via MSN to Mannyb18b
Re: Coil Overs Vs Springs
springs are non-adjustable and performance is not near that of a coilover set up. basically springs are just for the lowered stance, nothin more
Old 07-27-2004, 05:27 PM
scallywag scallywag is offline
What are your plans for the car..drag, auto x, or just for looks. and how much are you willing to spend. Since you are just lowering 1.5 inches I would say get springs. but if you are doing this for a auto x set up, then get some full bodied true coils. Don't waste your money on sleeve over coilovers. Too many bad things result from them. And a spring will perfrom just as good as a sleeve over coilover. Not to say that all sleeve overs are bad, but in the end after you replace the struts and get some good sleeve overs like gound control, you will be spending about as much as it would cost you to get a full bodied coilover which I personally feel are the best rout. But like I said it all depends on what you want out of you car!
Old 07-27-2004, 07:22 PM
its gunna be for show but im gunna do some enige mods so its not to slow so i dont want the worst feeling ride ever its gunna be kinda qucik but not full out drag
Old 07-28-2004, 09:09 AM
genkichild's Avatar
genkichild genkichild is offline
Send a message via AIM to genkichild Send a message via Yahoo to genkichild
lowering springs are for show, coilovers, for go.
I guess Tokico makes an ok entry level coilover for those with a tight budget. I think it's called Illumina. Like, 5 way adjustable and under a grand. Way better than a sleve setup. Check ebay.
Old 07-28-2004, 03:32 PM
JDMautogames.com's Avatar
JDMautogames.com JDMautogames.com is offline
Banned
go with the good brand coilovers, cuz it is adjustable. once you put lowering springs on, that'z it... it is not adjustable, if you don't like the spring, you have to get another set..... so go with coilovers...
Old 07-28-2004, 03:54 PM
aiight thanks all this was important because my friend is selling coilovers and i was wondering if i should get because i just bought rims and the gap is kinda big ill post pics once i get them installed
