Old 07-27-2004, 04:47 PM
Vincent Valentine Vincent Valentine is offline
engine swap question
ok...I have a SOHC engine in my stealth...and I want the AWD TT engine.
First off...Will the engine be able to fit/work in my car without special mods
Second off...Do I look for a stealth TT engine, or a VR4 engine
Third off...Where do I find said engine?????
Thanks for the help
Old 07-27-2004, 05:07 PM
Raz_Kaz Raz_Kaz is offline
Re: engine swap question
The TT engine will fit no problem (Stealth or VR4 have the same TT engines)....
The problem with this is the drivetrain layout, the SOHC is FWD and your going to have to change all of that to AWD (too much money and time IMO)
Old 07-29-2004, 01:54 PM
alan92rttt's Avatar
alan92rttt alan92rttt is offline
Re: Re: engine swap question
Um, NO.
You can (and may have) bolt the TT engine to the FWD trans.
You will need more than the engine tho. You'll need wiring, intakpiping, ECU, and many other components to make it work .
Check the FWD modifications forum on 3si.org. Their are many user that have done this on that site.
Alan Michigan 3S
The Toy 1992 Dodge Stealth RT/TT 13.3 @ 102mph
The Daily Driver 1998 3000GT SL
www.3sgto.org - The New home for 3S Enthusiasts
Old 08-19-2004, 10:40 AM
Hotshot8792 Hotshot8792 is offline
you'll also need to beef up your tranny a little too. Hell, Ty from speed factor is already on his 7th FWD transmission because he keeps shearing the gears or blowing the differential.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 08-20-2004, 09:32 PM
StealthModifier StealthModifier is offline
hotshot.. i thought u said b4 uve put 350wHP on a fwd with a tranny cooler... what would be different about a TT engine?.. that only has 320HP.. and thats not wHP
