Old 07-27-2004, 04:48 PM
alan92rttt's Avatar
alan92rttt alan92rttt is offline
13.39 @ 102
A friend took this and I thought I'd share. If I can get the AF tuned and the boost up and the knock under control I think I can have easy 12's
http://bloatedgoatz.com/Assets/image...4/JeffnAln.WMV
Alan Michigan 3S
The Toy 1992 Dodge Stealth RT/TT 13.3 @ 102mph
The Daily Driver 1998 3000GT SL
www.3sgto.org - The New home for 3S Enthusiasts
Old 07-27-2004, 06:23 PM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
Re: 13.39 @ 102
are you using a boost controller? because with your upgrades and a boost controller, you should be making better times than 13.3
Old 07-27-2004, 08:25 PM
alan92rttt's Avatar
Re: 13.39 @ 102
I was running 14psi
getting knock counts into hi 20's
Running rich, 820 egt's and .98 o2's
As I said when I get it tuned in I should get 12's easy.
Alan Michigan 3S
Old 07-28-2004, 12:17 AM
youngvr4's Avatar
STREET RACING GURU
Re: 13.39 @ 102
doesn't the super afc help your rich problem out?
Old 07-28-2004, 12:45 AM
alan92rttt's Avatar
Re: 13.39 @ 102
Yes, the afc can correct the running rich. I've made some changes since that run and the car is faster egt's are close to 890. But, I'm still getting knock and running rich. I need to get to the track again so I can try and get it tunned better.
Alan Michigan 3S
Old 07-28-2004, 12:50 AM
Hotshot8792 Hotshot8792 is offline
Alan, almighty mod of 3si
man, you should be hittin a lot better times and much higher traps with 13g turbos!
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 07-28-2004, 12:55 AM
alan92rttt's Avatar
Re: 13.39 @ 102
Well duh, thats why we've been talking about the fact it not tuned correctly yet.
Hell the car and I have less than 10 trips down the drag strip.
Alan Michigan 3S
Old 07-28-2004, 01:12 AM
youngvr4's Avatar
STREET RACING GURU
Re: Re: 13.39 @ 102
that sucks cause i'm also running rich and was planning on getting a super afc to fix the problem
Old 07-28-2004, 01:38 AM
it might be time to invest $300 into a wideband tuner
Old 07-28-2004, 02:23 AM
youngvr4's Avatar
STREET RACING GURU
Re: 13.39 @ 102
*clearing my throat* more info
Old 07-28-2004, 06:37 AM
BB1970's Avatar
BB1970 BB1970 is offline
Re: 13.39 @ 102
nice video alan, im sure its just a matter of time....
keep us posted.
brian
1993 Mitsubishi GTO Twin Turbo (RHD) NOW SOLD!!!
9b turbos with manual boost valve mod set @14psi
turbo xs type h-rfl blow off valve
blitz dome filter
sachs clutch
completely de-catted
fuel pump voltage rewire mod
ebc redstuff front brake pads
greddy fully automatic turbo timer
now drives a sensible family sedan. A 340hp 1997 mitsubishi evolution IV
Old 07-28-2004, 07:46 AM
alan92rttt's Avatar
Re: 13.39 @ 102
YEs, Its just a matter of time. THe afc is a tool not a quick fix it takes time to get it right(or a dyno and a profissional tuner)
My knock numbers have me more conserned right now.
Alan Michigan 3S
Old 07-28-2004, 10:35 AM
YogsVR4's Avatar
YogsVR4 YogsVR4 is offline
Funding the welfare state
Send a message via AIM to YogsVR4
Considering the knocking issue, 13.39 isn't bad at all. I hope I see your 12 second time slip before the summer is over
Resistance Is Futile (If < 1ohm)
Old 07-28-2004, 11:29 AM
alan92rttt's Avatar
Re: 13.39 @ 102
If I stoppeed being nice to my trans I could probably get a 12.9 now.
I got a 13.4 in indy with a 2.1 60ft.
Alan Michigan 3S
Old 07-29-2004, 02:21 AM
azn3000GTRacer azn3000GTRacer is offline
Re: 13.39 @ 102
lol 13.3 at 102 lol dang must be one hell of a launch cause iam running my best et time from the last time i was at the drag was 13.8 at 104
