Old 07-27-2004, 03:39 PM
TurboJoE21 TurboJoE21 is offline
Send a message via Yahoo to TurboJoE21
RPS Carbon Carbon Clutch
Does anyone have the RPS Carbon Carbon clutch and the lightweight flywheel, and the 1 piece carbon fiber driveshaft on there car? If so how does the car (vr4) drive?
Old 07-27-2004, 04:46 PM
lemon1438 lemon1438 is offline
I have the clutch for sale...look a couple threads down. These clutches are supposed to be just as easy to drive as stock. It requires a little bit more gas to start going, requires a higher rev to launch since its a lightweight flywheel, and the clutch pressure is almost identical.
-Ryan
Old 07-27-2004, 05:02 PM
Re: RPS Carbon Carbon Clutch
is there any differance in the way the car drives? does the car takeoff faster would this make my 1/4 times a bit better?
Old 07-28-2004, 01:45 PM
The revs pickup faster because of the lightweight flywheel, which would answer your other questions if you put two and two together. I already described how it would drive also. The main purpose of this clutch is to put all the power to the floor because it can handle high HP engines and not blow.
-Ryan
